Should i worry about oil starvation?
  • Zundfolge85
    • Jul 2023
    • 19
    Hello, just wondering if anyone has some advice for me. I have an e30 m10b18. At what point does this engine start to suffer from oil starvation? I know with some engines a fairly well designed baffle in the pan can be a massive improvement. A better question is, should I be worried about oil starvation if i’m consistently driving hard in the mountains, canyon carving in between states, sometimes cornering hard every few seconds for an hour at a time? the rocky mountains are badass for driving. I’m sure plenty of you have some insight into this.
  • 82eye
    • Jan 2009
    • 2109
    it's a pretty stout little engine and has fairly large oil capacity. i don't think i'd be worried.
    • reelizmpro
      • 9559
      Oil moving away from the pick up on long right turns is a problem for E30 M3's because of the sump design, so taller aftermarket baffles were a common modification at the time when most were tracked. The M10 sump doesn't have that issue AFAIK. Canyon carving shouldn't be a problem as long as the oil level is topped off.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • TobyB
        • 5298
        not on street tires on public roads, no.
        The E30M10 pan is what we put into
        2002 race cars to help with oil starvation.
        If you're concerned, the place to start is with a good- quality
        mechanical oil pressure gauge.
        t
        • Zundfolge85
          • Jul 2023
          • 19
          Thanks!
          • Zundfolge85
            • Jul 2023
            • 19
            Thats good to hear, thank you
            • Zundfolge85
              • Jul 2023
              • 19
              t
              awesome, thanks for your time
