Main bearing caps….HELP
  • StephenIX
    • Feb 2023
    • 5
    So I’m i getting into an engine rebuild and I managed to mix up my main bearing caps. So posts say the they are number 1 - 7 from factor, but mine are definitely not….. what should I do? Am I screwed?
  • 82eye
    • Jan 2009
    • 1952
    do you have any pics? never seen an m20 that didn't number the caps.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5455
      maybe hes talking about connecting rod caps
      • StephenIX
        • Feb 2023
        • 5
        Might be different for an ix.
        • 82eye
          • Jan 2009
          • 1952
          mine looked the same on the last build but there was a number where the g was embossed.
          • TobyB
            • 5222
            I once did this with a Mitsubishi engine-
            there are a pretty finite number of possibilities, if you go one at a time, and use plastigauge...
            M10 rods and mains aren't marked from the factory, but I forget about M20s
            t
            • digger
              • Nov 2005
              • 6044
              you might also find some discoloration, machining marks, scores, mismatch or other witness marks that could also lead you to either the correct position or which is not correct. The caps on the rod are always easy due to this
              • 82eye
                • Jan 2009
                • 1952
                went looking online and see other unmarked sets so there must have been a change at some point.
