How does a bad Clutch Master Cyl behave/feel ?
  • Panici
    • Dec 2009
    • 2483
    Drove my orange E36 328i for the first time in some months yesterday.
    The ride to work was fine, maybe the clutch engagement point was a little high? No slipping at WOT.
    On the way back from work, started shifting hard (force required to engage lever into next gear).
    By the time I got home, with the clutch pedal pressed to the floor, the car would still roll as if clutch was partially engaged. I couldn't pull the shifter out of gear.
    Checked the brake fluid and it wasn't low.
    I replaced the slave cyl previously.
    When that was going bad, it felt like pedal going to the floor and staying there. Could sometimes pump it up. Loss of brake fluid as well.
    Just thinking out loud, but when a master cyl goes bad, can the fluid leak past the seal?
    Would this produce less hydraulic pressure to send to the slave, and leave the clutch partially engaged?
  • ehrawn
    • Aug 2023
    • 206
    Those are all common symptoms of failure in the clutch system, but it could be anything: master/ slave cylinders, lines or the clutch, itself. You could try to inspect each component to narrow down which one (or multiple) is having problems, or just replace everything, depending on you tolerance for downtime.
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5555
      sometimes fluid just moves past the cylinder seal
      have someone depress the pedal and crack the slave bleeder and see what happens
      EDIT;
      thinking about this a little more
      here at the shop bad masters come in with a pedal to the floor 9/10 times
      usually with that kind of an issue you describes it a bad clutch spring/pressure plate
      Just do what I mentioned above. If you get a good fountain of brake fluid then it's most likely a bad clutch. Not necessarily a worn friction plate but something in the pressure plate, or clutch springs.
      Also, try pumping the clutch repeatedly and see if it works better. If it's bleeding off pressure as you actuate, doing this will help build pressure
      • Panici
        • Dec 2009
        • 2483
        EDIT;
        I did try pumping the clutch that day, it didn't seem to make a difference.
        I will try with the bleeder as you've suggested.
        Hoping I don't have to drop the trans, will probably throw a new master on it before I go that far. I have a brand new one in the basement.
        • lukeADE335i
          • Apr 2013
          • 1386
          That sounds more like clutch failure than the master cylinder to me, but fingers crossed. When my master cylinder was on its way out, the pedal would slowly get lower and lower while I was driving, but you could pump it back up.
          My e30: OEM+ with M30B35
          • varg
            Florida Turbo Man
            • May 2014
            • 3404
            That doesn't sound like a clutch master cylinder failure to me. My master cylinder failure modes have been limp pedal goes to the floor and not much happens (internal bypass; no hydraulic pressure), and a leak. It's easy enough to hold the pedal down and crack the bleeder to see if any pressure building but a bad master cylinder usually has an associated change of feel. When I've had a high engagement point and clutch failing to disengage is typically due to a damaged clutch disc or pressure plate.
            IG @turbovarg
            '91 318is, M20 turbo
            • Panici
              • Dec 2009
              • 2483
              That is what it's sounding like.
              May be time for an inspection hole. Think I have an old endoscope cam somewhere.
              • varg
                Florida Turbo Man
                • May 2014
                • 3404
                That's what I did when my clutch was sticking years ago. I drilled a hole in the bottom of the bellhousing and set a camera up under it with the car on stands so that I could see what was going on.
                IG @turbovarg
