Corrado Reliable DD?
  • 2002maniac
    • 4260
    L!
      • 34844
      Originally posted by SLUCK
      not true. VWs can last long past the 300,000 mark. just the same as BMWs. g60s need some real love but they can be just as reliable as any e30.
      PS i have been drinking so disregard any info i post.
      ask cramer about that.. I bet he disagrees.
      • Scarlet_Pimpernel
        • 151
        I thought i could daily a corrado... WRONG! i have had four vr6's and the corrado vr6 was the fastest vr i owned... but the worst. And distributor sucks. coil pack is better. But when you buy a corrado, You get married to it. If you want a rado, you will have to give up your e30. Dont get me wrong they are bad ass cars. But i actually came from a corrado and got the e30.
        But you need a decent amount of money to keep it going. And be prepared for lots of weird problems.. Like the bucking branco issue!!! which mine had.. and i never figured out the problem.
        "life's like the hair outta your ass... short and full of shit...":blowup:
        • Collin
          • 1736
          There is a reason they call them "hitler's revenege"
          The Keystone Killers
          With 73k+ post, you'd think he'd have learned a little about life.
          • cramer
            • 1812
            I do ;)
            I've owned mine for over 12 years and have 198k on it. The G60 while not being the most powerful motor is based off the bulletproof 1.8L that VW has had in all sorts of cars. The charger on mine is original with the apex seals being replaced at 160k.
            Corrados can easily be reliable if you maintain them like any other VW or BMW that is 20 years old. Buy one that has a maintenance history.
            Common areas that break: Rear spoiler motor, sunroof tracks (will vent but not slide back), power window regulators. G60s have the chargers that are a wear item, VR6s have timing chain guides that go. Not an expensive fix if you do it yourself, but time consuming.
            Chris
            90 Corrado/91 M3/01 M5
            • graphikg
              • Jan 2008
              • 1614
              Maybe I should just stick with a used 240sx. Fun but still very reliable.
              • hotballs
                • 1155
                queen of the vw stable.
                • nickpdx
                  • 679
                  lol
                  • kishg
                    • Sep 2006
                    • 2624
                    ride your bike instead..
                    '12 F30 328i Sport Line
                    '91 SpecE30 #523
                    '00 Ford F-350 Dually Tow Vehicle
                    BMWCCA #360858 NASA #
                    128290
                    • markseven
                      • Sep 2006
                      • 5327
                      Or get a miata.
                      I Timothy 2:1-2
                      • sljbps
                        • 34
                        Corrados are ROCK SOLID *cough*, speaking if which i have one forsale, interested? ;) ( its not running at the moment.....lol)
                        all kidding aside i really do have one forsale LMK :)
                        • graphikg
                          • Jan 2008
                          • 1614
                          Trust me, I would. Its just that I transport client's, and I work in mental health. I may only make them more insane. :crazy:
                          • M-technik-3
                            • 18946
                            So wouldn't a Crown Vic be more suitable with locking rear doors.
                            J/K
                            • BTP325ic
                              • Apr 2009
                              • 700
                              what he said.
                              Originally posted by FetusGoulash
                              Like ANY car you buy the previous maintenance will determine how long it lasts as a daily driver. Buy something that has been in a good home most its life and not had the snot kicked out of it by a bunch of 16 yr. old kids. The Corrado will be no worse or no better then a comparable mk2/mk3 VW in terms of reliability. Prices for replacement parts may be more expensive from most parts stores because its for that car but most of the important stuff is identical to those found on your run of the mill jetta and golfs.
                              As M-technik-3 just said, the G60 motor has a weak charger. If the seller cant prove its been rebuilt in the past then expect it to blow up. they only last up to 200k kms before eating themselves. However the rest of that motor is dead simple and cheap and easy to maintain so that makes it desirable as a DD
                              VR6 have timing chains on the trans side of the motor which involves removing transmission and basically pulling the engine to replace. If they make noise they need to be replaced. that would be the biggest thing to look out for.
                              I say get a well sorted VR6 and have fun with it.
