Rotor set screws
  • Wh33lhop
    • 11705
    Rotor set screws
    What size drill bit am I going to need? :p
    paint sucks
  • mattdk318i
    • Jun 2006
    • 3953
    I just used a 3/8 to pop the head off(wasnt reusing the rotor) and once the rotor was off i grabbed the stud with vicegrips
    • Dave
      E30 RAT
      • 11675
      1. Cut a slot in it with dremel
      2. If needed, PB Blaster soak it
      3. USe flathead screwdriver
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
      • Wh33lhop
        • 11705
        Have you ever DEALT with one of these things? After many coats of WD40 and PBB it still would not budge. Allen wrench > flathead screwdriver torque-wise. :p
        paint sucks
        • Wh33lhop
          • 11705
          I may just do that.
          Now to find a cordless drill. :(
          paint sucks
          • mattdk318i
            • Jun 2006
            • 3953
            Same here. I couldnt get anything to budge mine either. Much less get enough torque on a screwdriver
            • Dave
              E30 RAT
              • 11675
              Umm, yeah. On several cars. Even the ones from NJ and MASS that seemed to be rusted on came off after I soaked them with PB. I have drilled one out that was particularly stubborn, but all the others just needed PB, and if the allen head was stripped, I cut the slot in it.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • Aptyp
                • 6584
                get an impact driver, works amazing.
                • Wh33lhop
                  • 11705
                  Good call, I may do that.
                  paint sucks
                  • Joe318is
                    • Sep 2005
                    • 6451
                    before you do anything... heat, hammer, allen. works every time
                    after that, do you really need to know the fucking bit size to drill it out? WTF kid, just hit it with any dull bit you have clamoring around in the bottom of your empty crapsman 3 drawer 'tool box', give up... drink a beer.... go to bed angry.
                    fuck man!
                    Originally posted by vlad
                    • Simon S
                      • Oct 2004
                      • 3758
                      dremel cut-off wheel slot + impact driver has saved me more times than I'd like..
                      Joe's right about heat too. For times when i know it's gonna be fuct- PB soaking and one of those smaller propane torches really does the trick.
                      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                      • Jon325i
                        • 6934
                        Indeed this is a proven technique. Has worked for me many times.
                        Rides...
                        1991 325i - sold :(
                        2004 2WD Frontier King Cab
                        RIP #17 Jules Bianchi
                        • Philo
                          Ich esse kleine Kinder
                          • 3334
                          Above is a good one.
                          I usually use an easy-out. I did experience a problem with it once though. While I was attempting to back it out, the easy-out broke off into the set screw. . . . P.S. It's near impossible to drill that metal out.
                          -tim
                          Originally posted by Jordan
                          I like the stance
                            • 34839
                            why are you guys tightening these down so much?
                            finger tight, with some copper anti seize, you should even be able to reuse them a few times.
                            • Joe318is
                              • Sep 2005
                              • 6451
                              considering these cars are 20 years old, its a safe bet that anti seize was not used by the PO
