E30 Flip key?
  • hamann318is
    • 3382
    Originally posted by Ryan Stewart
    The best you can do is an E32/E34 key which has the light in it and is a bit thicker.
    Hey, you can always duct tape your fob to your current key. ;)
    The BMW 318 is back. With a vengeance.
    • Ryan Stewart
      I Love Miatas
      • 8978
      ohhh, classy.
      The new fobs for DEI alarms are about the perfect size now. It would be great if thye had a way in which you could take your factory blank and snap the fob around the top of it. All of the late model vehicles I have had came with the triangle headed master blank.
      Im now E30less.
      • DarkWing6
        • Apr 2004
        • 7144
        Do you think a good locksmith or someone like that could shave down the newer model ones to fit a key like ours?
        • bimmerphile
          • 3495
          no. they're steel.
          • Jordan
            • 12913
            Last night I was bored....
            Spare keyless entry remote + spare key = awesome.
            I don't much care for the faux carbon fiber on the keyfob but thats what came with my alarm/keyless entry.
            This thing is badass. :)
            https://mtechniqueabs.com/
            • rwh11385
              lance_entities
              • 18403
              Badass, except when you go to start your car and press down on the panic button.
              • parkerbink
                • Jun 2004
                • 10138
                You could charge peope to convert their fobs for them!
                • Ryan Stewart
                  I Love Miatas
                  • 8978
                  I might try that with the new smaller fobs from DEI. Id much rather not have a chain on my key.
                  Im now E30less.
                  • royalflush313
                    • Mar 2004
                    • 2070
                    Flip key would be cool, but I'm pretty happy with my little leather cover. OEM part too
                    ~ Go Canucks Go! ~
                    • cramer
                      • 1812
                      well without pics, i'm not sure how much of this will make sense (all the links were dead on VWVortex)
                      You can modify a VW/Audi flip key to work with the DEI mini remote (transplant the guts of the DEI mini into the flip key)
                      Then, all you need to do is get a copy of your key made, remove the blank from the flip key and cut your to match (the flip key is cut down at the end to slide into the flip key and a slot is cut for the pin that slides down to lock it into place) . Then all you need to do is get rid of the VW/Audi logo ;)
                      I have a flip key that i modified to work with my early VW key, but my alpine alarm remotes are too big to fit into the flip key. If you are interested, i'll take some shots of the how to modify the spare key to work with the flip key remote.
                      Chris
                      90 Corrado/91 M3/01 M5
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        PLEASE!
                        Originally posted by Gruelius
                        • hamann318is
                          • 3382
                          PLEASE!
                          • Jordan
                            • 12913
                            Nah, there is plenty of room to turn the key without being anywhere near the buttons. They take a decent amount of force to actually push anyways. Hasn't been a problem yet.
                            • Pat W
                              • May 2004
                              • 321
                              thats pretty nice jordan....i have the flip key its cool diffrent if u will.....but im trying to get an alarm put into it theres no point in caring it around with the key to the door lol....to bulky keep working on the alarms
                              JDM no more
                              • cramer
                                • 1812
                                ok here are the pics
                                2 piece Remote closed:
                                key out, other side
                                here is the pin you need to press out to remove the key (pin is already removed in this pic) I used a thumb tack and a hammer to press it out
                                The key is removed and you can see the grove the the pin fits into to lock it in place
                                comparison of the BMW key to the MKIV VW key
                                I used a full metal copy (no rubber portion) since i had to cut it up to match the shape of the MKIV key. You will also need to grind about 1/16" total of both sides to match the width. This is so the key will fit into the remote when folded back.
                                (please ignore my measure once, cut twice work. The next key I did for a friend turned out looking like factory ;))
                                and here is the remote portion taken apart to show the size of the circuit board
                                DEI mini remotes is the only ones i've found small enough to fit inside
                                Chris
