Diesel Questions
  • riverdale21
    • Mar 2004
    • 786
    #31
    Originally posted by PanamaE30
    no, more difficulty. M50 is an OBD-I engine. New diesels are OBD-II if i'm not mistaken. That alone is a problem, not to mention the EWS issues you'd have to sort out.
    Plus, the M50 sends signals compatible with the E30 instrument cluster, newer engines do not; unless i'm mistaken.
    If I'm not mistaken you can find the M51 in a OBD-I style configuration from the E34. I would totally dig going with the engine from a E46 330d but the expense and complexity is a deterrent to me.
    • BavarianBimmer
      • 951
      #32
      I was talking about the M51 engine If i'm not mistaken ;)
      1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
      1997 E36 328iT
      1990 E30 325iT 24v SOLD
      1989 E30 325i 2.7i M-Technic II SOLD
      • PanamaE30
        • Oct 2004
        • 768
        #33
        Oh ok, my bad.
        I was tunnelvisioned on those sexy variable twin turbos :)
        1988 325iC - "Betty" - Daily Driver/Project Car.
        1993 318i - "The Golden Dream" - Dad's Car.
        1995 318ti - "Hellrot" - R.I.P.
        • riverdale21
          • Mar 2004
          • 786
          #34
          So in theory the existing fuel pump and lines would be ok with diesel? I would go ahead and swap to a clean new fuel filter during the swap and clean out all the lines before proceeding. Anything else aside from that?
          • BavarianBimmer
            • 951
            #35
            no just the tank
            the rest from a diesel
            diesel fuel pumps are different I think
            1997 E36 328iT
            • Jonathan M3
              • 1837
              #36
              It'd be pointless. You'd never make up the cost of the swap from saved fueling costs.
              Just buy an m10 or eta powered E30. 30+mpg easy and gasoline is cheaper than diesel.
              '05 E46 M3 Imolarot/Cinnamon - CURRENT
              '98 E36 M3 Estorilblau/Dove - SOLD
              '90 E30 M3 Brilliantrot/Black - SOLD
              SRS BSNS Motorsports - 24hrs of LeMons Racer
              • riverdale21
                • Mar 2004
                • 786
                #37
                If I'm planning on keeping this car forever and I take 8+ hour road trips regularly I think it would be worth it.
                • Rob
                  • 8166
                  #38
                  but who actually keeps a car forever? especially folks our age?
                  BEERTECH
                  • riverdale21
                    • Mar 2004
                    • 786
                    #39
                    I'm probably on the older range of this group of car fiends. And if I invested enough money into a car I love I would keep it forever.
                    • BavarianBimmer
                      • 951
                      #40
                      dunno but I would keep my Mtechs as long as possible too
                      1997 E36 328iT
                      • riverdale21
                        • Mar 2004
                        • 786
                        #41
                        And I think it would be very safe to assume that Jordan is planning on keeping his E30 for years if not forever. Especially after all the work he has done to it. That is a labor of love my friends.
                        • Eric
                          • 5142
                          #42
                          to try and answer your origional question...
                          In CA you definetly CANNOT change a gasser to a diesel. the car would not pass smog, and then would be illegal to drive. I'm sure in GA you have smog as well, so without lookking at your lawbook, I would say that you cannot put a diesel into a gas car.
                          if you really want a newer diesel motor, I would buy a 524td and stick the new motor in there... that way you won't have to worry about different fuel pumps, fuel lines and so forth.
                          BTW, I pay 1,89 a gallon for diesel, at the same station gas is 2.05 for 87.
                          I also have a friend that has a new bug diesel (bought becuase he commutes 60 miles on way, not becuase he liked bug) anyways we went to vages a year back, and averaged 40mpg doing about 90+ with 4 pretty big dudes in the car (I was the smallest 180lbs)
                          • Digitalwave
                            is a poseur
                            • 6300
                            #43
                            That must have been a sight, 4 huge guys in a new Beetle :)
                            RISING EDGE
                            • Jand3rson
                              • 37587
                              #44
                              They are actually pretty roomy inside, TJ. My mom has one, and I like riding in it. Lots of legroom.
                              • riverdale21
                                • Mar 2004
                                • 786
                                #45
                                Looking at the website http://www.cleanairforce.com/engine.htm on emissions regulations in Georgia I see the following:
                                "Diesel posered vehicles that have been converted to operate on gasoline must meet the emissions standards and applicable emission control equipment for the year, make, model of its equivalent gasoline vehicle's body and chassis. Simply put, a diesel-to-gasoline conversion is legal if the gasoline engine used was originally available from the original auto manufacture in the same year body/chassis as the diesel engine."
                                There was no mention of a gasoline to diesel conversion so I take it that it would be the same requirements for the reverse procedure. I take that to mean that I can swap a diesel engine into a previously gas powered car as long as a diesel was originally offered by the manufacturer in that particular chassis. Also I must use a engine from the same model year or newer. In my case I was going to use the engine from a E34 525tds in a E28. I am assuming that all of this would be legal if I did actually go through with it and it passed emissions requirements.
