Diesel Questions
  • kansas-ix
    • Jan 2004
    • 1600
    #61
    oops
    E30 325ix 62k
    • kansas-ix
      • Jan 2004
      • 1600
      #62
      Originally posted by BavarianBimmer
      E38 :
      -740d M67D40 8cil has 250hp (290hp Kempower Belgium chipped ;) )
      MMm! that would certainly be a tasty motor in an e30.
      E30 325ix 62k
      • riverdale21
        • Mar 2004
        • 786
        #63
        Originally posted by nando
        Originally posted by Charlie
        RWD, diesel.
        -Charlie
        too bad those things top out at 80mph
        Too bad you still get just 12mpg too.
        • Eric
          • 5139
          #64
          RWD, diesel.
          -Charlie
          hell no, not mine! I blow smoke at people at 90mph! Ive never really taken it over 100mph but there deinetly is power to do so!
          • BavarianBimmer
            • 951
            #65
            My old M21 324d top out at 110mph (with effort) :twisted:
            1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
            1997 E36 328iT
            1990 E30 325iT 24v SOLD
            1989 E30 325i 2.7i M-Technic II SOLD
            • robert325is
              • Aug 2004
              • 1171
              #66
              my dad's '02 F-250 Diesel topped out at 99 just b/c the stock chip shut it down w/ the speed limiter.. its only turned around 2800 rpm at 95
                • 34837
                #67
                I dunno, my friend's ford diesel truck tops out at about 80 (the rev limiter). must be a different motor.
                • riverdale21
                  • Mar 2004
                  • 786
                  #68
                  C'mon man, I'm not talking about Fords here. I'm talking about BMWs. This is after all an E30 forum. Even though I am discussing the possibility of swapping a motor into an E28. Whatever, same brand.
                  At any rate what was your fuel consumption for your M41 powered car? And was power sufficient to be a comfortable daily driver?
                  • riverdale21
                    • Mar 2004
                    • 786
                    #69
                    Can a diesel motor be modified the same way as a petrol engine? Like spark plugs and wires? J/k. I know they dont have those.
                    What I mean is turbo wise. Can you use a turbo designed for a petrol car of the same displacement or does a diesel motor have different flow requirements. I know the power band is a lot narrower for a diesel so I would have to take that into account. Anyone know?
                    • YAN-3
                      • Jan 2004
                      • 6018
                      #70
                      wow i never thought anyone else would ever want a 324TD. I HAVE ONE AND I WANT A GAS GUZELING ///M3
                      • BavarianBimmer
                        • 951
                        #71
                        I think it's easier
                        you can increase more power with just a simple chip
                        exemple:
                        a local tuner claims 190hp and 390Nm for an M47d20tu engine ('00 E46 320d)
                        and I know people with that chip they were talking about 215hp on the dyno
                        1997 E36 328iT
                        • riverdale21
                          • Mar 2004
                          • 786
                          #72
                          I was going to try (eventually) to find an M51 from a E34 525tds and cram it into an E28. I am aware of the usual avenues of diesel performance... larger injectors, chips, exhaust, manifolds, etc. The only thing I was curious about was the turbo.
                          I would imagine you would want something with a slightly smaller diameter than a traditional petrol engine of the same displacement to compensate for the shorter rev range. That way you can make full boost before 4250rpm or something like that. Now I just have to find some compressor maps and calculate air flow to see what kind of turbo could make enough boost at such low rpms.
                          Another question I have... does anyone know how much boost stock turbo diesels usually run? Also what do they redline at?
                          • BavarianBimmer
                            • 951
                            #73
                            I tought from 0.7 bar till 2.0 bar (Volkswagen TDI's )
                            and redline at +- 5.250 rpm
                            1997 E36 328iT
                            • riverdale21
                              • Mar 2004
                              • 786
                              #74
                              .7 bar at idle? So it's 2.0 bar max boost.
                              • BavarianBimmer
                                • 951
                                #75
                                0.7 bar max boost
                                the most i've heard was 2.0 bar (VW)
                                in general it's around the 1.4 bar
                                1997 E36 328iT
