Magnaflow or Vibrant?
  • Suspence
    • Jul 2009
    • 943
    Can't decide, I have a 88 e30 with K&N Intake, IE Headers, Dinan Chip and a few other small goodies. What do you think would sound better?
    DetailsVibrant 1040 Muffler with 2.5" Center Inlet and Dual 3.5" Straight Cut, Double Wall Tips with Beveled Edges. The body of this oval muffler measures 5" High x 9" Wide, overall length is 23". Features 2-1/2" ID slip fit inlet for your exhaust tubing. 100% TIG welded stainless steel.Vibrant StreetPower Stainless Steel Universal Performance MufflersThe StreetPower Universal Performance Muffler series offers a large selection of muffler/tip combinations to suit just about anyone's preferences. However, as good as these mufflers look on the car, it's ultimately the performance gains and deep exhaust tone they produce that will put a smile on your face every time you go for a drive.Features of StreetPower Universal Performance Mufflers100% T304 Stainless Steel ConstructionExhaust tips and inlet/outlet necks are TIG welded for maximum durabilityMirror Polished Finish for show quality looks"True Straight Through" internals for unrestricted exhaust flow and maximum performance gainsCompletely reversible muffler for flexibility needed by custom exhaust fabricatorsPremium multi-layer sound suppression materialsProduces a very distinctive deep exhaust toneCenter Inlet with a Variety of Single and Dual Tip OutletsSuitable for both Naturally Aspirated and Forced Induction Applications
  • dinanm3atl
    • Feb 2007
    • 7305
    I really liked my vibrant on my e36. They made a bolt on. Have heard the E30s with Magnaflow though and they sound great...
      • 34839
      2.25" single inlet mufflers suck. that's smaller than stock. Plus magnaflows are loud. Maybe I'm just old, but I'd go for the vibrant. At least you can get a 2.5" inlet.
      • BigTe30
        • 207
        i couldn't be haappier with my magnaflow 14815
        • Kershaw
          • 11822
          unless someone with knowledge in fluid dynamics can chime in here and give you the flow rates of dual 2.25" and what would be an equivalent flow rate in a single inlet, i would stick to dual 2.25" in.
          i have no knowledge in fluid dynamics, so im just throwing this out there. but i'd go to at least a 2.75", if not a 3" for the inlet if you make it a single. but as i said, i think sticking to dual 2.25" in is ideal.
          AWD > RWD
            • 34839
            a single 2.25" definitely flows less than stock (approximately dual 1 7/8"). It comes down to surface area and cross section. The cross section is much smaller, enough to offset the decrease in surface area.
            2.5" single inlet would be fine for a mostly stock engine
            • e30_3I8I
              • Sep 2009
              • 305
              i have the 2.25 magna flow muffler... i like it alot i bit loud but it only bothers neighbors/ or people on the streets=]
              my project
              http://r3vlimited.com/board/showthread.php?t=164374
              • Kershaw
                • 11822
                i thought stock was a dual 2.25", or is that just the outer diameter of the pipes? is the 1 7/8" OD or ID?
                AWD > RWD
                • z31maniac
                  • 17566
                  Thermal Research and Development.
                  That's the muffler I'd buy.
                  www.gutenparts.com
                    • 34839
                    no, it's way smaller than that
                    the actual dimension is in MM, I don't remember exactly, I just know it's close to 1 7/8". I think that's OD.
                    The cross sectional area of a single 2.25" muffler would be reduced by over an inch and a half from stock.
                    • Kershaw
                      • 11822
                      good info, thanks.
                      AWD > RWD
                      • dinanm3atl
                        • Feb 2007
                        • 7305
                        IIRC a late model E36 M3 has 2" or 2.25" dual. The e30 is much smaller.
                        • Suspence
                          • Jul 2009
                          • 943
                          Hmm, I still can't decide.
