Car isnt starting.. Possible Kill Switch?
  • Peterkaczynski
    • Nov 2008
    • 2587
    hey guys so my e30 isnt starting she cranks but nothing. ive had this a couple of time where id pull put of a parking spot and shed choke up and die.. i replaced my fuel filter, airfilter, and a bunch of tother things which needed to be fixed and after i took her from the shoip because they realigned my exhaust i drove hope about a mile and she died in my driveway yesterday morning and she cranks but doesnt start.
    this little random switch is located under the radiocontrol and central control unit right under everything im thinking its a kll switch
    here are pics any help would be appreciated.
    andf then i have this cool thing the car had when i got it it doesnt work but looks like it came stock with the car. (dont mind the dirt)
    TIA for any help
    e24 e9 e30
    IG: peterkaczynski
  • Kershaw
    • 11822
    unplug the afm and crank?
    have you tried flipping the little red switch? most likely it turns on and off the old escort radar detector.
    AWD > RWD
    • Peterkaczynski
      • Nov 2008
      • 2587
      thats a good guess hm it might but it feels like there are 3 stops when i flip the switch, left. middle, right..i tried starting on all of them and nothing :(
      e24 e9 e30
      IG: peterkaczynski
      • Peterkaczynski
        • Nov 2008
        • 2587
        and how do i unplug the amf
        e24 e9 e30
        IG: peterkaczynski
        • Philo
          Ich esse kleine Kinder
          • 3334
          Probably get more help if you post in the correct forum.
          It has nothing to do with that switch. I would check the fuel pressure coming off the rail, then check the CPS. Above all, I would buy a Bentley and use it.
          -tim
          Originally posted by Jordan
          I like the stance
          • nismoman
            • Jul 2006
            • 246
            listen when you turn the key on to the start position. do you hear a whine(fuel pump) if not replace your fuel pump relay. also could be a shitty engine ground. check all of your ground wires on your engine block. you can swap your relays around, i cant remember if e30 are the same as e36 engines but you should be able to swap one of the three over to each other. incase you dont know which one is your fuel pump relay its next to your inake and it has a green and purple wire going to it.
            1985 s50b30, 91 front and rear valence, e30 m3 suspension, advance design coilovers, GC camber caster plates full solid bushings alla round, adjustable rear arms, ireland sways front and back, ireland big brake kit front and back , team dynamics wheels, 24lb injectore ltw fly, intake , headers, exhaust, so forth so on......
            • quikveedb2
              • Sep 2007
              • 2258
              Main relay?
              You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
              • Jparkr
                HR Admin
                • Jan 2006
                • 3494
                That switch is probably for that hidden radar detector system.
                Was the check engine light on before it died, or was it idling really rough before?
                1987 PRO-3 car /1990 325is (2.7i Concours)
                • Julien
                  • 7471
                  does it have spark? does the fuel pump run?
                  more than likely main relay or OBC immobilizer
                  Build Threads:
                  • McGyver
                    • 4619
                    the CODE function?
                    • Peterkaczynski
                      • Nov 2008
                      • 2587
                      :up:thanks man
                      e24 e9 e30
                      IG: peterkaczynski
                      • Car Addict
                        • Mar 2007
                        • 1100
                        just remember all you need to start a car is fuel, spark, compression and timing. so just narrow down from there.
                        easiest to check is spark then compression. if you have both go to fuel see if your fuel pump is functioning then, if it is check pressure and volume at the rail. if you have both check for signal at the injectors. and if all of it checks out go for timing.
