Megasquirt Mayhem. Please Help.
  • Chabs
    • Jan 2010
    • 538
    So me and my buddy were out driving around in my e30, computer plugged into the megasquirt, making minor adjustments and experimenting a bit.. and we changed something and the car stalled. We changed it right back and burned it to the ECU, and the car wouldn't start. Everything we changed was restored to original settings as well..
    The engine would catch but wouldn't stay on and the exhaust smelled strongly of gas. Feels like there wasn't enough gas or the spark timing was wrong..
    WHAT THE FUCK!?!!?!
    Josh
    http://www.r3vlimited.com/board/showthread.php?t=159843
  • tn325i
    • 1154
    I have had similar incidents... Usually I can go back and re-open and re-burn the file.. Hopefully you are saving files along the way as you make changes so you have backups of what was working previously...
    • whodwho
      • Jun 2008
      • 1547
      Re-flash firmware and then burn the last known good msq if just reloading the msq doesn't fix it.
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • Chabs
        • Jan 2010
        • 538
        i'll try those. anyone else??
        Josh
          • 34835
          did you by chance change a setting that was highlighted in red?
          • Chabs
            • Jan 2010
            • 538
            noticed those at the bottom, but didnt touch any of them.
            Josh
            • gearheadE30
              • Jun 2007
              • 3734
              You may have to rewrite the firmware. Did you try flood clearing it when it was flooded? If it caught, it would eventually run for a very short time, and you would at least know that ignition was working correctly.
              Project M42 Turbo
              • Chabs
                • Jan 2010
                • 538
                okay, got the car started, loaded another tune and it worked. however while we were experimenting yesterday and screwed up, we were trying to fix this weird thing my car is doing.
                when it runs smoothly, the AFR at idle i hovers around 4, however it switches every once in a while, not sure why, and drops even further. anyone know what the problem is?
                Josh
                  • 34835
                  4? do you mean 14? if it's reading 4 you haven't calibrated your O2 sensor correctly.
                  • Chabs
                    • Jan 2010
                    • 538
                    it was at 14.7 but once it heated up, it dropped down to 4 and at some points even 3 or 2, its kindof surprising that the car was still running.
                    Josh
                      • 34835
                      That has to be an error, either in the calibration of your sensor or the sensor is bad itself. Usually you don't read below 10:1. What sensor do you have? Wideband or narrowband?
                      • Chabs
                        • Jan 2010
                        • 538
                        innovate wideband
                        Josh
                          • 34835
                          have you connected directly to the Innovate to see what it's reading? I'm willing to bed your AFR calibration in Megasquirt is wrong or hasn't been done.
                          • Chabs
                            • Jan 2010
                            • 538
                            haven't connected it to the innovate.. how would i do that? is it possible that i need to replace the o2 sensor?
                            Josh
                              • 34835
                              with the serial cable it came with. If you don't have the CD that came with it anymore, you can download the instruction manual from Innovate. It tells you how to set everything up. :)
                              I really doubt the sensor is bad - even if it were, the default programming doesn't read below ~9:1. 4:1 is so far off the chart it has to be calibration.
