Megasquirt Mayhem. Please Help.
  • Chabs
    • Jan 2010
    • 538
    awesome, just downloaded the instruction manual. the owner before me didnt know anything about this stuff, and it says to calibrate every 10 000 miles or twice a year. it was DEFINITELY not done.
    i'll let you know how it goes,
    thanks a lot.
    Josh
    http://www.r3vlimited.com/board/showthread.php?t=159843
      • 34844
      thanks a lot.
      you also need to calibrate the sensor in megasquirt. It's under the Tools menu - Calibrate AFR curve. make sure your project is set to wideband and not narrowband..
      • Chabs
        • Jan 2010
        • 538
        just did it, and now im getting readings in between 2 and 3. when i revved the engine it dropped to about 1.5 for a split second and the car almost died..
        its running VERY rich, the exhaust smells like gas.
        what... the fuck
        Josh
          • 34844
          did you calibrate the Megasquirt curve yet?
          • Chabs
            • Jan 2010
            • 538
            nope, we didnt...what will that change and how is it done?
            Im not familiar enough with MS to know all these things haha. it was in my e30 when i bought it and im trying to get a hang of it.
            Josh
              • 34844
              you using megatune or tuner studio?
              in any case, it's under the Tools menu > Calibrate AFR curve. You probably want to set it to Innovate Default.
              • Chabs
                • Jan 2010
                • 538
                using megatune. thanks for the help, gave up for today but will be back at it within a couple of days haha
                Josh
                  • 34844
                  whatever you do, don't trust your AFR gauge until you're sure it reads the same in both logworks and megatune.
                  • Danny
                    • 14216
                    haven't connected it to the innovate.. how would i do that? is it possible that i need to replace the o2 sensor?
                    Really?
                    That's your issue right there.
                    • maniacmatt
                      • Feb 2007
                      • 483
                      I am actually having pretty much the same issue. I have an rs4pro3 plug and play (its not by the way) megasquirt setup. I have an Innovate LC-1 wideband configured to dual wideband outputs. I have one output connected to a gauge and one to the megasquirt.
                      My gauge reads 12-14 AFR's and in megatune it reads like 4 or 5. I don't have the calibrate AFR curve option under tools in my version of megatune.
                      Oh and I tested the outputs on my LC-1 and get exactly the same voltage on both of them.
                        • 34844
                        you need to calibrate the gauge in megasquirt. this is basic setup stuff, non-optional.
                        • Danny
                          • 14216
                          Seriously, have you guys read nothing on the subject?
                          • maniacmatt
                            • Feb 2007
                            • 483
                            Thats the whole reason I bought a supposedly plug and play kit, I expected the basic set-up to be done.
                            I don't know where in megatune to adjust the settings with my version as it is not located under the tools menu.
                              • 34844
                              you can't expect it to be calibrated to your car though. you still have to do *some* work.
                              tools > calibrate AFR table. If it's not there try enabling advanced options. also you need to make sure your project is set to wideband.
                              • maniacmatt
                                • Feb 2007
                                • 483
                                I am using megatune 2.25 and the MS1 Extra 029y4 project. I don't see anything like what you are describing for calibrating the o2 sensor.
                                I have Basic Settings>Exhaust Gas Settings. I have the EGO sensor type set to wideband and then there are things like EGO switch point, Ignition events per second and on and on.
                                I don't see anything else that could be used to calibrate for the o2 sensor.
