Those who replaced airbag wheel with standard wheel
  • reelizmpro
    • 9553
    I just replaced my airbag wheel with M Tech 2 on my convertible. I used 4 washers behind the nut to get it to work. It seems the wheel is cocked to the left a bit. I have heard of this before but was wondering if it's an airbag car thing or what? The M tech 2 in my 88 M3 seems fine but its a non airbag car.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
  • tomkate28
    • 140
    I used an extra spacer,not washers and it fit great.
    • IRON-E
      • 16548
      Please lead me to the spacers you speak of...
      @IRON-E30 aka Edwin:D
      • der affe
        Technical
        • Dec 2005
        • 8452
        it is the regular spacer that is on the air bag wheel already. you can see it in the parts breakdown of realoem.
        just order one from the dealer or blunt. IIRC it was around $10.
        • tomkate28
          • 140
          Its the spacer behind steering wheel on all e30s,i grabbed a few extras at picknpull. Part # 32311120260
          • der affe
            Technical
            • Dec 2005
            • 8452
            you could do that too, but around here at most of the PNP's the keys are gone so the steering wheel locks are stuck so you can't get the wheel off. i have had to leave several nice MT-1 wheels behind because of this.
            you also may need to pull out 2 plastic contact pegs/springs to stop a rubbing/squeeking noise after you do it too.
            if you search, there are a couple of threads that show you where they are so you can just pull them when you switch the wheels.
            • tomkate28
              • 140
              I dont need a key to pull any e23,e24,e28 or e30 fine spline wheel.;-)
              • bmwstephen
                • 2463
                did u not use the spacer that came with the wheel?
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  you need 2 of them. the stock one + it's twin.
                  • Matt-B
                    The Waffler
                    • 3856
                    spacer_____wheel_____washer_spacer_ NUT
                    < front of car
                    • der affe
                      Technical
                      • Dec 2005
                      • 8452
                      yep, that's how it goes.
                      • tomkate28
                        • 140
                        I did spacer,spacer,wheel,washer,nut and it functions perfectly.
                        • Matt-B
                          The Waffler
                          • 3856
                          and you have an annoying gap between column an wheel right?
                          • tomkate28
                            • 140
                            Havent noticed any gap,ill check tomorrow. It functions and feels perfect.
                            • ethree
                              • Aug 2007
                              • 1213
                              Next time try your key, It will get one out of three or so columns unlocked.
