I'm running out of options...
  • e30frosh
    • Dec 2004
    • 2170
    Recently me 90 325i has been under the knife due to poor warm up running. I've tried and replaced numerous items to no avail. She starts and idles just fine and will pull well to approximately 2500. Then she'll buck like a stabbed mule until 3000 and run just fine through the rest of the powerband. All variations to throttle yield the same results. Then she reaches regular operating temperature and everything is kosher.
    So far I've:
    Intake bellows
    Plugs
    Bavauto Performance wires
    New Fuel Injection Temp sensor(water temp sensor is only a year old and operates normally)
    Cap/Rotor
    Cleaned AFM with mass air cleaner and found no binding in the flap motion
    Inspected all grounds and vacuum lines
    All injectors are operating with no signs of leaks
    1/2 can of seafoam
    Any help would be greatly appreciated.
    Every day I wake up we drink a lot of coffee and watch the CNN
    Every day I wake up to a bowl of clover honey and let the locusts fly in.
    Lobsterbacks attack the town again
    Wrap all my things in aluminum
    Beams of darkness streak across the sky
    Pink rays from the ancient satellite
    Every time I look out my window same three dogs looking back at me.
    Every time I open my windows cranes fly in to terrorize me.
  • Dj Buttchug
    • Jun 2010
    • 7688
    check and see if your tps is operating properly. Use a DMM to check the resistance across the connectors in closed and open position. bentley should give the operating specs??
    only other thing i can think of would be defective maf. Ive seen all sorts of weird things happen especially at different engine speeds. (certain vibrations cause the problem)
    not sure if this helps just some ideas
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • FredK
      • 14763
      Yeah, I think worn traces on the AFM can cause this. There are some helpful writeups floating around about how to bend the wiper arm on the carbon resistor to avoid the "stabbed mule" phenomena.
      • e30frosh
        • Dec 2004
        • 2170
        I've questioned the tps, but am I wrong in thinking that wouldn't effect just warm up running?
        I'll search for those writeups, but I'm a bit leery on breaking the seal on the AFM. I guess she had to be devirginized at some point. But I'm still thinking that if the traces were worn, it would do it all the time. Not just at warm up.
        Thanks for the info guys.
        AJ
        • kingston
          • Jun 2010
          • 2669
          Perhaps a silly question, as I am still fairly new to E30s... Is there a seperate program in the ECU for warm-up running? I know this is the case in some cars...
          Originally posted by LJ851
          kingston is the play by play announcer for this thread.
          ‘Tis by the grace of God that my cars run!
          Originally posted by unloadedak
          #teamross
          Siobhan's Build Thread - UPDATED!
          • Dj Buttchug
            • Jun 2010
            • 7688
            you have to remember tho that resistance changes with temperature. So with that said the afm could very well be the issue. Ive seen this countless times. Maybe swap it with a well known working and see what happens.
            Ig:ryno_pzk
            • Cabriolet
              • 9620
              dying O2 sensor?
              Much wow
              I hate 4 doors
              • e30frosh
                • Dec 2004
                • 2170
                No codes are being thrown.
                dying O2 sensor?
                • e30frosh
                  • Dec 2004
                  • 2170
                  That is where I was getting confused. I'll swap them and see if that is the problem. If so, I'm just going to swap to the miller maf kit.
                  you have to remember tho that resistance changes ith temperature. So with that said the afm could very well be the issue. Ive seen this countless times. Maybe swap it with a well known working and see what happens.
                  • Need4Speed1299
                    • Oct 2007
                    • 119
                    On the 325e there is an Idle Control Module.
                    • bmw325csi
                      • May 2007
                      • 4045
                      don't mess with the afm, you will probably fuck it up more. Look into e36 mass air flow units, they can be had for under 100 bucks and its a relatively easy install.
                      harry/harout
                      • call me jack
                        • Jul 2010
                        • 425
                        this may sound ridiculous, but is your heater core hooked up? my car used to drive really weird, while warming up, then i hooked my heat back up and the problem went away completely.
                        • e30frosh
                          • Dec 2004
                          • 2170
                          Heat is all connected. Thanks for the heads up though.
                          • call me jack
                            • Jul 2010
                            • 425
                            well in that case i'm gonna say, once you've run all out of options, replace your heater... doesn't that sound exciting?
                            I'm on board for a bad o2 sensor as well; when i was trouble shooting my car, i thought i needed an o2 sensor as well...
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              What the hell are you talking about? You just can't plug a MAF into an m20 and have it work, you need to reprogram the DME. The signals from an afm and a maf are completely different.
                              '89 Alpine S52 with goodies
