Seat Belt Buckle Question?
  • archie
    • 5448
    My front inside passenger seat belt buckle don't catch unless you wiggle or push the buckle in at an angel,then it buckles.
    If you look inside the seat clip, you can see the metal clip thing staying down.The drivers side is not this way and it works fine.
    Question? Is this buckle trash or can it be fixed?
    88 M3 Diamantschwarz
    89 M3 Zinnoberrot
    56 Isetta
    LIKE ARCHIE'S on Facebook!
  • foofopps
    • Sep 2009
    • 529
    I had that problem, there was a piece of plastic that had broken off and was jamming it up. I opened it up and took out the broken piece and it worked for a little while and then it would inconsistantly latch or not latch. Sometimes taking like 3 tries. So I went to the junkyard and grabbed a few out of an e28 as well as a e32. They all worked well and I ended up using the a matching set of e28 ones. Hope that helps.
    Originally posted by b3albakii
    the head was okey .. and in a good mood
    no i didnt over heat it so much
    www.blunttech.com
    • jaywood
      • Jul 2010
      • 4528
      I have the same problem. I might just order a new one online somewhere.
      • bimmerboy08
        • Apr 2009
        • 353
        i had the same problem, for the frustration it was causing it was worth just buying a new one off bavauto.
        • archie
          • 5448
          do they open up? I tried with a screw driver and it cracked a little? whats the secret?
          just looked at Bav Autos website and I dont see them being sold?
          89 M3 Zinnoberrot
          56 Isetta
          • bmwstephen
            • 2463
            archie, i think you should just plan a list of thigns to do for ur e30 and go to a junkyard and start looking for parts. I got a seat belt buckle for 5 bucks at a pick n pull when mine was damage.
            • TS323
              • 359
              just steal one from the junkyard.
              • archie
                • 5448
                Got to do that but short on time.Was hoping to hook up with some one local.
                hahaha!
                89 M3 Zinnoberrot
                56 Isetta
                • Eecen
                  • Jun 2010
                  • 1235
                  No need to steal it, just put it in your pocket and walk out...anything that discreetly fits in your pocket is free ;)
                  I believe they're referred to as pocket parts
                  • duboy
                    • 83
                    i just changed mine out yesterday for a working one bought from a fellow r3v'er. old one went right in the trash...oh and jamming one of those in your pocket might elicit some odd looks...it's longer than it looks *cough*thatwhatshesaid*cough*
                    | '89 M3 | '93 M5 | '03 X5 4.6is | '03 325i | '87 190e 2.3-16 |
                    • !kid
                      • 1362
                      i have opened up a buckle for an E36. after we fixed what was wrong with it, the outer case whould not clip back together. it looked as though it was glued shut from the factory. i guess we just got lucky while prying it open.
                      to make it easy on yourself, try to find one in good shape at a junk yard or order one online.
                      :borg:
                      • archie
                        • 5448
                        Got a pm from a member who has one,thanks.
                        89 M3 Zinnoberrot
                        56 Isetta
                        • Kershaw
                          • 11822
                          they are ~$40 new at a dealership.
                          cheap insurance for something that will save your life in a car crash.
                          AWD > RWD
