Bmw e30 - Hunt for the 8sec is ON !!
  • karel
    • 234
    #166
    Originally posted by Massimo
    So I have been following your thread on PPF.
    I have never seen a girdle for a cam tray before. Should I even ask what crazy cam you are going to be running?
    thanks bro.. :D nice to hear..
    the girdle is an new thing im gonna test.. the m20 heads arent good when getting boosted.
    So this might get it a bit more stable.
    the cam im using is a bit monster.. its around 322degres
    you can hear it here at this startup video.
    startup
    https://www.facebook.com/karelsilhamotorsport/
    • Massimo
      • Jan 2008
      • 3207
      #167
      startup
      http://www.youtube.com/watch?v=KGNAL...1&feature=plcp
      Holy crap 322deg!! That things sounds so awesome idling.
      Well the girdle thing is defernetly interesting and would like to know more about if it works or not.
      • karel
        • 234
        #168
        hehe yeah.. the idling is crazy sound almost like an muscle car v8... and i wouldnt say thats good :hitler: :D
        • Cronopoulos
          • Jul 2011
          • 2187
          #169
          Great work, very sick build!
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • karel
            • 234
            #170
            Some pictures of the car from the local car meet last night
            Västeråsträff #2 2012 by EVikman Photography, on Flickr
            • Xat1cZ
              • 2020
              #171
              Lite bilder från västerås träffen igår.
              ...ganska säker på att majoriteten av forumet inte förstår svenska ;)
              cool looking car :D
              • silence
                • Jun 2007
                • 1824
                #172
                I like those wheels.
                •• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
                •• Rear Subframe Bushings • RTABs • Facebook ••
                • karel
                  • 234
                  #173
                  cool looking car :D
                  hahah jävla strul!! :D
                  • karel
                    • 234
                    #174
                    So yesterdays summery.
                    Went to Tobbe @
                    WiTune
                    to get some serious power out of the M20.
                    We did around 10-15 pulls without no problem what so ever.
                    Managed to get the low boost and low resistance tuning well..
                    then we went for the higher boost.. startad at 15psi(1bar) and everything worked well.
                    the we went for 24psi(1,6bar) we got around 540whp on first or second pull.. after that we went to 27psi(1,8bar) and after that we noticed that the oil was mixed with water.. looked more into it and the water reservoir was empty.. so that was it..
                    im gonna tear apart the block at the end of this week and see the damage.. Im thinking cracked head or cracked engine block.
                    the gasket isent an option, if so it should push out the water instead of consuming it and mixing it.
                    end quote -->
                    If it would all work out.. we would easily do 900whp+ today.. everything in the engine worked so good, and every boost gain we did it responded well... so getting 900whp out of m20 is still on !! >
                    im back soon again with some new parts .. and the dyno will be in august again..
                    Movie of one pull is coming.
                    • Massimo
                      • Jan 2008
                      • 3207
                      #175
                      bad luck man, good to see that giving up is not an option.
                      What boost pressure are you estimating for 900whp?
                      I can't remember but did you guys sleeve the block? I am assuming you did, but thought I would mention it anyways.
                      • StealthiE30
                        • Jun 2012
                        • 491
                        #176
                        I just creamed in my pretty pink panties Batman! :bow:
                        IcWhatUdidThere
                        • karel
                          • 234
                          #177
                          i will not give up :)
                          its not sleeved, and its an standard gasket :)
                          the dyno did some calculations, and if we would hit the 3.2 bars (48psi) as planned it would probably land somewhere above 900whp.
                          i will investigate it this weekend and see what needs to be done.
                          /k
                          • Massimo
                            • Jan 2008
                            • 3207
                            #178
                            /k
                            Wow going for 900 on a pritty much stock block, that is very impressive. I supose a sleeved block is always an option then.
                            3.2bar!!! man that made me laught simply because of the crazy numbers I am reading. I really can't wait to see this thing fly down that strip.
                            What crank are you using, is it a BMW crank or a custom item?
                            • Jean
                              • 18228
                              #179
                              Amazing build! Any more info on what was done to the rear fenders, and how much wider they ended up being?
                              Thanks! Your build is greaT!
                              • karel
                                • 234
                                #180
                                First attempt on the m20 WR in power..
                                540whp on the first pull on 22 psi with poor ignition..
                                cracked head or engine block.. will repair it and try again
