Quick! I need your advice R3V!
  • KenC
    King of Kegstands
    • 14396
    Originally posted by dannyyisntt
    thats up to you, you don't need to do both sides at the same time.
    diy for rebuild http://www.pelicanparts.com/bmw/tech...er-Rebuild.htm
    It's a bit of a pain in the ass fyi.
    You think rebuilding a caliper is a PITA!? It's one of the easiest jobs. They're single piston. Just one seal, one dust boot.
    Why not just extract the bleeder screw and get a new one?
    Originally posted by Gruelius
    • dannyyisntt
      • 3141
      If it's your first time rebuilding them it can be a PITA. For somebody else it's like a difficulty lvl 2 out of 10
      • dannyyisntt
        • 3141
        found shiboujin's rebuild video he made..
        • Heysüß
          • 911
          about halfway through my bitching I wrote why I couldn't:
          The old man was too impatient and snapped off the extractor screw as well before the pb blaster had had any time to do its thang. :(
          09/1989 325i 4 Door
          +M30 Swap
          +Z3 Steering Rack
          • Heysüß
            • 911
            http://www.youtube.com/watch?v=B6iyG...mbedded#at=453
            sweeeeeeeeetness!!! :nice:
            09/1989 325i 4 Door
            +M30 Swap
            +Z3 Steering Rack
            • nomansland92
              • 1657
              I snapped my driver side to i just bled it through the line and compressed the piston and it seamed to get all the air out because its work just fine ever since. But not a permanent fix
              IX being restored here
              Ix turbo build here
              • Simon S
                • Oct 2004
                • 3758
                plus one for rebuilding.
                Drill the fucker out. Take your time and periodically spray/rinse/cool with WD40. Run a tap through. New bleeder screw. Done.
                Sounds like you could get by w/out new seals even - but seal kits pretty cheap - and now that I think of it, if you did drill out the broken screw, I'd want to dismantle and rebuild just to be sure no metal shavings were inside the caliper. (potential to damage piston surfaces)
                Rebuilding is kind of a pain, but it is also rewarding when the job is done. (and WAY cheaper)
                Good luck. Don't be too hard on the old man.
                -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                • bimma360
                  • 1940
                  To me... a "remanufactured" caliper is as good as new. The rears from bavauto are $64 a piece which includes the refundable $20 core charge. All said and done it will run you $128 for two calipers and about $15 for shipping.... that puts you at $143 up front, and $103 after you get your core charge back.
                  OR spend the extra $7 bucks to qualify for free shipping at the $150 mark and walk away with 2 basically new calipers, and another $22 worth of stuff you may need for $110.
                  I remember what its like to be in college. But 100 bucks for basically new calipers is pretty cheap, and is def worth saving you the hassle.
                  E30 Dinan Turbo
                  • KirkerBezerker
                    • 441
                    Originally posted by Stanley Rockefeller
                    c.
                    dont' bother with a pair of used ones.
                    Don't waste anyones time here. You don't know shit about cars. Now go buy another merc to please you girlfriend.
                    • Heysüß
                      • 911
                      wow, i definitely like the way this route sounds. Unless anyone can give me a good reason to not buy these "remanufactured" calipers I may just buy them. Thanks man!
                      09/1989 325i 4 Door
                      +M30 Swap
                      +Z3 Steering Rack
                      • rightcoastbias
                        • 449
                        Jesus,
                        Go easy on your dad. He got the subframe out. :hitler: I've watched Andy rebuild many VW calipers. They're not cake, but it works. My vote is purchase a matching (Girling or ATE) junkyard caliper ($15) and order two Pelican Rebuild Kits ($7.50 ea).
                        Sorry about the screw extractor fail.
                        M52B28 OBD1 - G240 - S4.10
                        Stuff for Sale: 24v swap parts
                        • Heysüß
                          • 911
                          Originally posted by rightcoastbias
                          Jesus,
                          I know, he helped a lot. I just didn't like that I got yelled at when he was the one that snapped both the valve and extractor screw.
                          09/1989 325i 4 Door
                          +M30 Swap
                          +Z3 Steering Rack
                          • Heysüß
                            • 911
                            What probably made me snap was when he suggested drilling out and threading a bigger hole and replacing it with a bigger bleeding valve. It may work but you know how much of a girly scaredy cat I am when it comes to doing stuff like that Gabe.
                            09/1989 325i 4 Door
                            +M30 Swap
                            +Z3 Steering Rack
                            • StereoInstaller1
                              GAS
                              • 22679
                              I figure it like this: if you have to bleed the brakes, it isn't much more work to rebuild all the calipers, flush the fluid and clean the reservoir.
                              EDIT: Find yourself a garage buddy or three. Find an E30 buddy if possible.
                              Closing SOON!
                              Thanks for 10 years of fun!
                                • 34844
                                the napa calipers are very nice. can't go wrong there - same ones BMA sells.
                                spending money on a junkyard caliper and the wasting of time seems silly to me when the caliper, basically brand new, is $40. after you pay shipping, wait for it to arrive, spend an hour or more pulling a caliper of questionable history out of a junkyard car, what did you really save? and you'll still have a dirty, grungy old caliper, even if the seals are new.
                                With the rebuilt one, you pull it out of the box, put a new pad in, and bolt it to the car. done. and the best part is, you can drive down to the store and get one, right now..
