Need the help of R3V - Amputee Driving a Clutch
  • DaveSmed
    • Apr 2007
    • 1407
    #271
    That being said though, the motorcycle MC STILL won't work as it simply will not move enough fluid. 14mm and barely any stroke.... not gonna cut it.
    If you were to use something like the hydrovac, you would use a normal sized MC.
    Also, properly shifting clutchless wears out less shit. "Properly" is a significant part of that though.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • 5Toes
      • 9836
      #272
      Clutchless shifting is not that bad.. my friend does it all the time and I honestly cant feel a difference.
      I think I will go with the rod/stick idea for now, and master clutchless shifting.
      That hydrovac thing is awesome! But in reality, I dont think "that" much pressure would be needed to push on a diaphragm in one of those
      • Vtec?lol
        • Dec 2009
        • 3278
        #273
        If I had the resources I would love to test it all out.
        I wish I had an engineering degree.
        Now that I think of it, homeboy is right. Fabbing in a reducer would just make it harder. Sigh. I'm fairly positive the mc would move enough to disengage the clutch but it'll be hard.
        • homegrone30
          • Jun 2007
          • 1449
          #274
          I think you guys are overthinking this. And from what I understand no amputees like long car trips with there prosthetic on. What about a series of push pull levers on different pivot points to basically extend the pedal to the drivers leg? You could also set it up so there is a mechanical advantage to make a softer or harder pedal. Im thinking about the clutch side because my dad is a left leg amputee, but it could work just as easy for the driver.
          • Vtec?lol
            • Dec 2009
            • 3278
            #275
            Maybe an electronic clutch!
            • F34R
              sLaughter
              • 12376
              #276
              Originally posted by 5Toes
              How do my parents know what is best for me though?? Not trying to turn this that direction though
              This hydraulics conversation is very interesting. If anybody can prove a way to use a motorcycle m/c.. I am all ears
              Drive an auto, thread/
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • Exodus_2pt0
                • 5943
                #277
                That would be acceptable if there was a DSG box for the e30....
                No E30 Club
                • YosemiteSam
                  • Apr 2011
                  • 1303
                  #278
                  If you want I could put you in touch with a guy who does this kind of a thing for a living. I have a friend who's good friends with him.
                  • 5Toes
                    • 9836
                    #279
                    So thanks to a honda...
                    I may have figured out a way to do this!!!
                    Use a mechanical clutch! Like an integ
                    Any thoughts?
                    Nevermind.. this is near impossible.
                    • gte175x
                      • 150
                      #280
                      • Fusion
                        • Nov 2009
                        • 3659
                        #281
                        Couldn't a linear remote actuator be mounted with the right speed (out fast, in slower)?
                        Those things sell for around a hundred bucks.
                        • Vin-barrett
                          • Mar 2012
                          • 192
                          #282
                          I would suggest contacting Phil Hunt here in Jersey. He has been competitive in an all hand control ITB Volvo as well as the VW pictured here.
                          • Exodus_2pt0
                            • 5943
                            #283
                            Originally posted by gte175x
                            /thread
                            No E30 Club
                            • nick475
                              • Aug 2012
                              • 85
                              #284
                              ^^agreed. I just read through this whole thread. And a small hand operated lever on the shifter seems like it would be the best. You would have total control over clutch position, you get your left leg to drive like its an automatic. Not a lot of confusion. And its probably the most legal.
                              • nick475
                                • Aug 2012
                                • 85
                                #285
                                Also, if you were hurt and someone had to drive you, it wouldnt be any different than a normal manual
