Need the help of R3V - Amputee Driving a Clutch
What about a motorcyle m/c and a small remote booster (like a small mini cooper brake booster?)
like this - http://www.ebay.com/itm/SUZUKI-SAMUR...#ht_545wt_1110Comment
BroWorks.com Bro is a lifestyleComment
I have been trying to figure out how you could make this work...
Then I realized, that if you can get the car rolling, then you don't need a clutch really. I drive around all the time, only using the clutch for first gear. As long as you don't try to force it, no damage is done to the transmission.
Get rolling, and when you decide to shift ease off the throttle while applying pressure to the shifter lightly. The trans will literally fall out of gear, then apply pressure to the next gear. (not too much or you will grind, too little and you will grind. Its a sweet spot)
keep off the throttle and let the engine slow. Once the engine RPM's match the transmission, it will "fall" into the next gear. After a while you will learn where these sweet spots are, and it will come naturally.
Seriously, I do this all the time and have never had an issue. I was taught this technique by my Auto Tech teacher in high school. It doesn't allow for racing, but at least you could drive a manual.No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.Comment
synchros will never lastBroWorks.com Bro is a lifestyleComment
Tell that to my MKV Gli with 120k on the clock and original transmission, that held 400+whp until the motor let go.
It does not hurt the synchro's because the synchro's aren't needed in this situation.
The job of a synchro is to match Engine RPM to the transmission's RPM. Shifting the way I described only happens when the RPM's match, thats why it works.
Tons of people say what you just did, that the synchro's won't last. But yet I have personal experience that says they do. Along with many others that have first hand experience. I take it you don't. ;)No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.Comment
yeah you are just grinding the dogs teeth together every time you mess upBroWorks.com Bro is a lifestyleComment
honestly if you only stalled only once you might want to look into giving it a shot, at least before you custom fab a bunch of super complicated stuffBroWorks.com Bro is a lifestyleComment
Check this out (its already been mentioned in the thread btw)
To understand how that works, you need to know a bit about normal brake boosters. When you step on the pedal, your actually mechanically actuating a valve that allows the pressure differential to build across the diaphragm. Thats the dead spot you feel in the beginning of pedal travel.
The hydrovac booster pictured uses strictly hydraulic input to actuate the diaphragm differential valve and apply vacuum assist. There is no mechanical linkage connection to it. It's used in older trucks mainly (which means they are usually rather sizable) to provide power brakes while only requiring the much smaller master cylinder be near the pedal.-Dave
2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
Need some help figuring out the ETM?Comment
