Need the help of R3V - Amputee Driving a Clutch
  • LJ851
    • 7919
    #91
    Originally posted by Pantless Spency
    thad be me sir.
    I figured that would put your skirt in a bunch.
    Lorin
    The M30 is God's engine.
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7283
      #92
      not at all :P i'd just love to point out the obvious haha.
      • MattM
        • Apr 2009
        • 931
        #93
        my uncle is paralyzed from the waist down, yet he is still able to drive thanks to hand controlled gas and brake pedals(automatic). If you adapted a similar system then used your foot for the clutch its very do-able..
        Full Build Thread Here
        • CabbE30
          • Aug 2009
          • 2358
          #94
          Originally posted by 5Toes
          Oh I just built a simple solenoid valve. Well not a fully functioning valve but I get the idea.
          haha I took .5" PVC and wrapped solder around it. Well 12V 2 amps seered off the solder lol. So I took like 5 wraps of copper wire. Like 18 guage bare wire. It wasnt enough for a strong magnet but it held my steel bolt up fine.
          And the battery charger kept turning it self on and off, guess it was not used to such low resistance.
          Dream system would be a solenoid valve hooked up to like 80psi of air. Have button for it on shifter, then just hold button and shift.
          LIGHTNING FAST
          Well this sounds like a great idea! The only problem in thinking is how are you going to modulate the clutch with a push button? I can see it working for up/down shifts but modulation of the clutch is still required for these actions and especially for starting from a stop. You be doing burnouts every start.
          Maybe im missing somethig.
          • 5Toes
            • 9836
            #95
            Haha no I thought of that. Well it could have two switches.
            1 for "sport mode". Where it shifts lightning fast no restriction.
            1 for "normal mode". Where there is separate circuit that is opened up to limit airflow down to a lower PSI. Like50. Lower would push clutch in slower.
            Damn I feel like an engineer
            • 5Toes
              • 9836
              #96
              Hard part would be finding a compressor small enough.
              The tank could be under a seat, or mounted up under the car.
              The compressor would build up 80 psi while warming up, and that should last a while on say a 1 gallon tank. Then the compressor could keep up with everyday driving just fine!
              Now just somebody who knows what they are doing to help me. Lol
              • 5Toes
                • 9836
                #97
                This would be perfect
                http://www.amazon.com/gp/product/B00...T4Z07R8BEQ6Z7B
                • CabbE30
                  • Aug 2009
                  • 2358
                  #98
                  Get an old computer joystick for like flight games and mod that to use your switches. Thatd be balla!
                  Well actually itd look like shit in an e30 but still. Haha
                  • 5Toes
                    • 9836
                    #99
                    Ya Im not feeling joint stick idea
                    But I think I am onto something.
                    If I build this and it actually works. Money Money Money
                    • CabbE30
                      • Aug 2009
                      • 2358
                      #100
                      Could mount an air compressor in the trunk, run the lines by the fuel lines, up to the clutch. The electical lines would just follow the route back under the carpet to the trunk with all the other ones.
                      The joystick was a joke btw
                      • 5Toes
                        • 9836
                        #101
                        Yeah. But these things are loud.
                        Or get a compressor driven by belt off engine. Hmm that take alot of fab work though. and Id lose horsepower.
                        But the tank is small enough to mount under the car
                        • bimmerteck
                          • 762
                          #102
                          Viair makes great 12v pumps, I've used them for air ride setups for years, add a spare tire shaped tank and you good to go all stealth like.
                          With best-in-class design and performance, VIAIR compressors lead the market in quality, reliability, and convenience.
                          • 5Toes
                            • 9836
                            #103
                            Thanks!
                            • CabbE30
                              • Aug 2009
                              • 2358
                              #104
                              Sorry if my suggestions are unhelpful. Just really interested in the outcome.
                              You could mount it on the rear passenger side under the car. Like opposite of the exhaust. This would be the farthest point away from passengers also.
                              • 5Toes
                                • 9836
                                #105
                                Not too bad on price either!
