S52B32 in an ix?
  • fast1eddy
    • 40
    S52B32 in an ix?
    Can it be done? has it been done? There's a rare ix coupe with blown head gasket for sale in my area and a low mileage S52B32 also for sale. Sounds like it could make a nice combo if it can be done. Any advice?
  • rhett325i
    • Jan 2005
    • 575
    • Kershaw
      • 11822
      it has been done. as you can see by the above video. s54 swap has been done too.
      you will need to cut the front half of the m20 ix oil pan and weld it to the s52 oil pan. apparently it will just bolt up.
      AWD > RWD
      • lennon
        • Jun 2008
        • 1416
        e34 525ix pan?
        • Kershaw
          • 11822
          yeah. good luck finding that.
          AWD > RWD
          • lennon
            • Jun 2008
            • 1416
            if you're doing an s52 ix swap, you should be ready to hunt/pay. i'm sure it wouldn't be hard to find a used one on ebay in europe. or buy it new.
            bmw part number: 11131730429
            never done a 24v ix swap, so not even sure that pan is what will work.
            • glucklich21
              • 1912
              Won't work, axle shafts are a different size.
                • 34844
                Originally posted by lennon
                e34 525ix pan?
                You'll need far more than just a pan to do it that way, it ends up being more work than modifying the e30 one.
                Basically with a modified pan it bolts in (using ix engine mount arms even). The main difficulty lies with brake booster/manifold clearance.
                • lennon
                  • Jun 2008
                  • 1416
                  more clearance issues than normal 24v swap? engine at less of an angle in the ix?
                  • fast1eddy
                    • 40
                    Car sold 15 minutes before I called. So guess it a mute point now. Thanks for the answers though.
                      • 34844
                      Yes it will sit at the m20's angle instead.
                      • lennon
                        • Jun 2008
                        • 1416
                        oh i missed the part about using the m20 ix arms. wasn't thinking about that.
