My freshly finished swap is grinding. Please Help!
  • McGyver
    • 4636
    I just finished the front of my 5-lug swap. The rear were running nicely with no problems after a moderate fender roll.
    The fronts are grinding bad, and based on the perfect condition of the inside of the wheel it has to be the brakes. I'm running e36 m3 brakes that I just rebuilt. The inside of the wheels were also coated with greasy metal particles. I hadn't put any grease on the metal part that the pads slide on when i bolted it back up though.
    When driving you can hear/feel the grinding. It also drives like shit. It sorta feels like it dives when the wheel is turned. The tire doesnt appear to be rubbing the fender. The brakes were properly bled, but feel spongy. It did lock up the front wheels when I put the petal to the floor.
    Could my calipers be frozen on the rotor? How can i fix this tonight? I'm supposed to drive to DC tomorrow and I really want to take this car.
  • Kershaw
    • 11822
    brake dust shield?
    AWD > RWD
    • McGyver
      • 4636
      didnt use one.
      It is grinding BAD. Like stopping the car quick, not just rubbing like a backing plate would. I didnt lube the sliding pins, so im going to try that with some grease i have laying around.
      • McGyver
        • 4636
        no advice? i tried greasing the par where the pads slide and the rods that slide through the bushings. it didnt help at all.
        • BigD
          • Jul 2006
          • 1085
          When you install the calipers, do they go on easy or are you forcing the pads over the rotor? Like before putting the caliper on, are you able to push the caliper piston all the way into the caliper, and the brakes don't bind, you can spin each wheel by hand?
          • McGyver
            • 4636
            both wheels spin by hand, but the pads rub more than i would expect they should. i am basically just slipping the caliper and pads onto the rotor.
            • YeOldeBuggy
              • 208
              Sounds like a fucked wheel bearing, judging by your description of the greasy metal particles, were the parts used?
              Thad.
              Need BMW parts?
              http://www.blunttech.com
              or face ultimate peril.
              • nrubenstein
                • 3148
                Pull the calipers and see if the noise persists when you spin the wheel. It's pretty much got to be either brakes or bearings.
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
                • BigD
                  • Jul 2006
                  • 1085
                  Any difference with the engine turned on? (maybe air in the abs causing problems?) Did you also change the booster/master? (maybe there's preload on the mc?)
                  • evil_twin
                    • Nov 2007
                    • 2965
                    sounds like a wheel bearing.
                    Paypal: vdang5@gmail.com
                    Delta Auto Care
                    2875-C Towerview Road
                    Herndon, VA
                    703.435.1375
                    My Feedback Thread: Evil_Twin
                    • McGyver
                      • 4636
                      brand new wheel bearings. all i did was swap out the suspension components. I also went from rubber to SS brake lines. is it possible that air somewhere in the lines or behind the brake pistons is causing this?
                      • blueapplesoda
                        • Dec 2005
                        • 1904
                        air in the brake system would cause the side that has air in it to barely work at all.
                        take pics?
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          This doesn't sound so much like a brake problem as a bearing problem.... If the hubs were subject to impact when they were installed, they could already be bad.
                          Project M42 Turbo
                          • mikeedler
                            • 6707
                            are your wheels rubbing on the strut tube?
                            • McGyver
                              • 4636
                              Well I did bleed the brakes in the exact wrong order (FL-FR-RL-RR) and I had the engine running when I did it. So when I get home i'll try it properly. The bearings were pressed on and both roll smoothly. It seems like the front brakes just wont release. Thanks to everyone who posted for trying to figure it out for me!
                              *mods, since its not urgent any more, could you move this to the 5-lug conversion section?
