Front rotor allen bolt stripped, now what?
  • Eecen
    • Jun 2010
    • 1235
    Torch > penetrent
      • 34844
      Originally posted by Hick
      lol, you say that now... if you plan on using one of these, make sure you have AT LEAST 5 extra bits lying around
      I've had an electric impact driver for a few years now, I've never broken a bit?
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        I have found that not using a cheap ass Harbor Freight Impact Screwdriver & Tips will also prevent this.
        • Hick
          • Sep 2005
          • 6451
          Originally posted by Eecen
          Torch > penetrent
          +99999999999
          Also, as for the bits, it never fails. Even 'nice' crapsman bits break on me
          Originally posted by vlad
            • 34844
            you suck :p
            I dunno, I don't have anything special - some from the local hardware store (that are probably from HF anyway), some random ones, and some black and decker bits that came from my wife's toolbox before we were married. Most of them have seen a lot of use, too.
            • delatlanta1281
              Dart Master
              • Mar 2006
              • 10317
              +1 on the impact, but as far as bits go, you will never know what you are getting. Manufacturers outsource 100% of their bits... even Vermont American does now. Cost>Quality.
              Yours truly,
              Rich
              you kids get off my lawn.....
              • bimmer630
                • 1230
                The easiest way around this is to just beat on the back of the rotor on the opposite side of the hold down screw. Wear safety goggles. The rotor will break at the area where the hold down goes through, and once you get all the shattered parts of rotor off from around the screw, you can now put vice grips on it and work it out. Might need penetrant/heat but usually not.
                Sheesh havent any of you guys worked in a flatrate shop?
                • Nick_S
                  • Apr 2011
                  • 3658
                  I would soak the remaining bit of the screw in PB, give it some heat and grab with some vice grips. Or get an easy-out.... +1 on anti-seize. Any bolt or screw I take out of my car gets wire wheeled and a nice coat of anti-seize. Good luck :up:
                  91 318is M50 swapped
                  05 Honda Pilot
                  24V swap thread
                  • foofopps
                    • Sep 2009
                    • 529
                    Yeah I got the screw out right away with vice grips, no problemo.
                    Originally posted by b3albakii
                    the head was okey .. and in a good mood
                    no i didnt over heat it so much
                    www.blunttech.com
                    • Mossman
                      • Apr 2006
                      • 1961
                      This man speaks the truth, a decent sized hammer makes quick work of the rotor, throw a lug bolt in there to catch it when you smash it off though. Half the time it splits in half around the annoying rotor set screw too, so you can smack off the other half that's hanging on for dear life and remove the screw by hand or with some pliers.
                      I also have a beat to shit torx bit that is totally useless for any task other than hammering into 5mm allen head bolts and making short work of it. I generally give it a quick full blast with 1/2" impact with a 1/2 to 3/8 adapter, pretty deadly combo.
                      it's insane how much better the 6mm ones on the newer bimmers are, it's harder to strip one of those than it is to not strip a 5mm e30 one, and that's pretty hard.
                      • xAZxE30x
                        • 1241
                        EZ out.
                        works every time!
                        • Roysneon
                          • 4505
                          Just had to do the same thing, drilled that bish out.
                          Originally posted by mbonanni
                          I am a pursit now.
                          • sweet6e30
                            • Feb 2011
                            • 531
                            u dont even need those fucking things. If your worring about them , you must be a fan of rebecca black!
                            my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                            • KenC
                              King of Kegstands
                              • 14396
                              Unless you have studs, the rotor won't stay on the edge of the hub because of the bevel.
                              Originally posted by Gruelius
                              • Charlie
                                kid tested, administrator approved
                                • 6686
                                15 seconds with a dremel and a flathead screwdriver, seriously, this isn't hard.
                                -Charlie
                                Swing wild, brake later, don't apologize.
                                '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                                FYYFF
