Has your E30 tried to kill you?
  • A_Whelan
    • Jul 2010
    • 691
    Hey,
    I'm fairly new when it comes to working on cars to the extent that I am about to do, an m50 engine swap. I'll have the help of my father through the swap so everything should be fine.
    However, I've read a few posts on r3V on ways that their e30's have taken swing at the owners, one of the worst has been a bumper tuck and inhaling the mist that comes out of the cylinders. I can also think of dropping the subframe and electrical shock (unplug the battery)
    What other ways can an e30 strike back?
    r3vlimited Lanyard Group Buy!!!
  • b*saint
    • 3794
    I nicked my knuckle on the alternator fan. I guess more of a bite.
    Ma che cazzo state dicendo? :|
    • matthugie
      • Mar 2004
      • 1810
      r3v is the most common, though only a small part of that is design.
      88 325is - S52 powered
      Originally posted by King Arthur
      We'll not risk another frontal assault, that rabbit's dynamite!
      • Sagaris
        • Sep 2009
        • 2243
        I installed drop hats which caused my steering to completely lock up as I was turning right to get on a freeway onramp. So not exactly the cars fault since I installed an aftermarket part that I was under the impression would work without flaw. I pulled over on the onramp and was able to force the steering free by grabbing the tire at 9 and 3 and giving it a solid yank.
        I took the suspension all apart , ground the drop hats down so they wouldn't lodge themselves into the inside of the strut tower and all has been well since.
        My other E30 had a little issue too: I had just gotten it, had been driving it for 10 minutes and decided to give it full throttle. It had some stupid pedal covers which jammed and the throttle stuck at full throttle. I grabbed neutral, switched the car off and reached down to un-stick the pedal in world record time.
        So in both cases, potential accidents were caused by parts that dont belong on the car to begin with.
        • merrrr
          • Jun 2010
          • 296
          my throttle got stuck wide open cus of the stupid cruise control cable got stuck on the throttle body.. i punched the clutch in and my car hit the r3v limiter for a few seconds until getting unstuck and scared a bunch of pedestrians. thank god for manual trans lol
          • xwill112x
            • Jan 2009
            • 4236
            fell off the stupid factory jack and almost killed me lol even with 1 jackstand already up under it.
            • mrsleeve
              • Mar 2005
              • 16387
              yes it had bitten me, and tried to kill me more than once
              Originally posted by Fusion
              William Pitt-
              • 16v of E30
                • 157
                not me but a friend had a diff sieze up at 80km/h
                • NKRoberts
                  • 909
                  Price of going low my friend :p
                  Vinyl Lettering
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    I've had my accelerator pedal stick wide open coming out of a corner in second while driving spiritedly on a back road, thank god I'm not a Prius driver or shit would have been bad.
                    I've also had it fall off the factory widow maker jack while removing a tire almost removing all my fingers, car fell and ended up resting with the lip of the brake rotor resting against the inner wheel lip, my fingers were between the wheel and the fender. Lesson learned: don't use that piece of shit jack on soft gravel and don't be careless.
                    Other than that nothing really comes to mind.
                    '89 Alpine S52 with goodies
                    • JTapper
                      • Sep 2009
                      • 847
                      I got kissed in the forehead by the oil drain tube for the head.
                      Now I know why they call it the suicide tube.
                      Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
                      • nickflic3
                        • Sep 2009
                        • 3564
                        Fucking factory jack... Nuff said :hitler:
                        Edit: Reason for jack failure was on my way to school on the freeway the rear shock bolt stripped out... Drove like 30 miles with no driver side rear shock. Talk about sketch...
                        Cammed B25 Swap Daily Driver
                        Updated 10/1
                        • ak-
                          • 12422
                          Had the car start to lean towards me while slowly on the factory jack, so I had to scramble getting the wheel back on.
                          Went through a puddle in the rain and got the powersteering wet I think(ripped boot?) and had my steering-wheel lock on me for a second.
                          1991 325iS turbo
                          • McGyver
                            • 4637
                            definitely had the accelerator cable get stuck on me at WOT when i was driving outta dc. (that was a fun time) nearly dropped the car on myself cuz i was being careless with jack stands. welded a socket wrench when i shorted the battery. Basically all the shit my cars give me is from careless or half-assed mistakes.
                            • BMWerke
                              • 893
                              i cut my knuckles countless times on the exhaust bracket during my tranny swap.
                              '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
                              '86 325e- Donor car for swap/parts car
                              '00 323i- BBS 197s Totalted
                              '89 740 turbo Volvo- Donated
