Has your E30 tried to kill you?
  • QUKBMER
    • 8178
    #46
    You forgot the part where you NFS drifted in between the rocks.
    dorifto s4v3d muh lyfe
    Oh snap! sorry i left that out. ;)
    • SA E30
      • 1248
      #47
      Mine hit me in the head...
      Came off the shitty widow maker jack, I had just finished with rear coilover install and was adjusting the ride height, saw the speedo plug out so figured I would pop it in quickly. Car shifted sideways and diff smacked my pip. Luckily I had the forsight to put the wheel I had removed under the rocker so it didn't come down too far...
      Still scary as shit. Never will I use the stock jack again.
      • TimKninja
        • 2131
        #48
        I keep a floor Jack in my trunk To avoid using the widow maker . Havent really been let down by my car after owning it a year now. Nor has it tried to kill me, Im OCD about jacking up my car and supporting it.
        1985 325e M50TU(Sold)
        1991 318is Slicktop (Sold)
        1990 325is Brilliantrot S50/5 Lug Swapped.
        1992 525i Manual shitbox Winter Beater
        • scrambles30
          • May 2011
          • 43
          #49
          Originally posted by b*saint
          I nicked my knuckle on the alternator fan. I guess more of a bite.
          Hahaha
          • Wh33lhop
            • 11705
            #50
            lost the entire wheel on the freeway. rear left wheel. once. towed home.
            lost the bottom bolt on my front right caliper. locked the wheel on a highway in the hills.
            over heated once. towed home
            blew a tire.
            caught the interior on fire.
            r12 line blew and fogged up the whole inside of the car.
            been also towed home for:
            the timing mark breaking off the flywheel.
            hitting a curb in the dark and breaking the control arm.
            fuel pump died on a track day.
            Holy shit. Cars hate you.
            paint sucks
            • Good & Tight
              • Apr 2004
              • 2057
              #51
              Mine tried to kill me, but I killed it first.
              Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
              ____________________________
              E-mail Panayiotisx2@gmail.com
              Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
              • bmwstephen
                • 2463
                #52
                what the hell happened?!
                • bmwguy325is
                  • May 2011
                  • 1263
                  #53
                  ^----OUCH! That went over a few times I am guessing.
                  I had a caliper bolt come out one time on my right front caliper. I happened while on the freeway so I drive quite some time. The first place I came to that I had to slow down was a interchange ramp. The right front wheel locked because the caliper logged it self against the inside of the wheel. I spun around at 55 mph. Fastest 360 I have ever done. Best part is a cop saw it all and it was 2am so he thought I was drunk.
                  sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                  The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                  • CHIF8008
                    • 3447
                    #54
                    hood falls onto my head
                    starter shocks me and started a lil fire :o
                    brake bracket bolt backed out on freeway and caliper started grinding the inside on my rim
                    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                    -The Beauty in the Tragedy-
                    MECHANIC SMASH!!- (you all know you do it)
                    Got Drop?? ;-)
                    But of course
                    E30s are know to be notoriously really really really ridiculously good looking
                    • Kershaw
                      • 11822
                      #55
                      spring compressor broke when nearly fully compressed. i felt it snap and got the fuck out of the wheel well. a chunk of it just barely grazed my head.
                      AWD > RWD
                      • E30_Pare
                        • 7801
                        #56
                        stock height
                        drum brakes
                        no abs
                        shit tires
                        sealed beams
                        dark canyons
                        no guard rails
                        ex girl w/ friend
                        cellphones
                        high pitched screaming
                        loose gravel shoulder
                        cliff.
                        Barely slid to a stop with my front wheels inches from the cliff. fyi this is Woosley cyn CA
                        Also like one of the only turns without a guard rail.
                        Stock jack falling while changing a flat sat on my rear drums & almost crushed my leg.
                        DREWLIENTE
                        1$ PShops PM me
                          • 34847
                          #57
                          I HATE using spring compressors!
                          a tip for removing stock springs up front (assuming you aren't putting them back in). Lay the strut on some grass. stand on the spring. Use an impact to pop the top nut free. it will "pop" but it's not going to hurt anything since you are standing on the spring. no scary as hell spring compressors ready to explode in your face with 400+ lbs of pressure, and it's way faster too.
                          • frankenbeemer
                            • Sep 2009
                            • 2260
                            #58
                            Something about that picture makes me imagine Otis with a turbo manifold in each hand screaming "come at me bro!"
                            Don't buy an e30
                            They're stupid
                            1989 325is Raged on then sold.
                            1988 325 SETA 2DR Beaten to death, then parted.
                            1988 325 SETA 4DR Parted.
                            1990 325i Cabrio Daily'd, then stored 2 yrs ago.
