Should I buy?
  • Bimmerfanatik
    • May 2004
    • 5349
    I wasn't aware that you could put OBD-II engines into E30's without converting them.
    Shit man, if you can put a V12 or a Chevy 350 in an e30, anything is possible ;)
    I'MA BUILD MES A ROKIT BEE EMM DUBBYA, AND WHOOP DAT DER HONDA CAR DOWN DA STREET! WAIT'LL THE GIRLIES SEE ME!
    • Digitalwave
      is a poseur
      • 6299
      BIRNG ON THE RAIINNN FOR MAD DRIFZT
      RISING EDGE
      • permit
        • Mar 2005
        • 3363
        You'll need the wiring harness from a vanos M50, intake manifold from an M50, S50 intake (if you want), M50 knock sensors (and some wiring to make it work, ask JasonH), e34 oil pan and dipstick, M50 fuel rail cover, power steering hoses (if you look up the part #, you'll be given the wrong part, but you can make it work anyways by bending it), 413 ecu (no ews, you'll need custom software anyways), ix/320i brake booster, you can use the M52 exhaust manifold, but it'll be a different setup than if you did M50 EM (M52 has more flow, I stuck with M50 because I didn't want to pay for more custom exhaust work. If you do stick with the M52 ones, you'll need to weld two holes closed and find plugs for the O2 sensors), those are some of the things I can think of. Then there's tiny stuff that you discover down the line.
        Anyone else can chime in on what else is needed, however I'm sure there's a write-up for it.
        • Bimmerfanatik
          • May 2004
          • 5349
          Originally posted by permit
          wiring harness from a vanos M50 (has to be vanos?)
          intake manifold from an M50 (vanos/non? doesnt matter?)
          S50 intake (if you want) (if I don't, what can I use?)
          M50 knock sensors (and some wiring to make it work, ask JasonH) (vanos/non? matter?)
          M50 fuel rail cover
          you can use the M52 exhaust manifold but it'll be a different setup than if you did M50 EM (M52 has more flow, I stuck with M50 because I didn't want to pay for more custom exhaust work. If you do stick with the M52 ones, you'll need to weld two holes closed and find plugs for the O2 sensors), those are some of the things I can think of. Then there's tiny stuff that you discover down the line.
          Wow. So obviously more complicated than slapping an M50 in.
          Decisions decisions. If I decide to keep both my 92 non-vanos and this new M52, what will I need to buy aside from the two motors?
          • permit
            • Mar 2005
            • 3363
            [quote="Beemerfanatik"]
            M50 fuel rail cover
            Has to be vanos because you need the plug on the harness for the vanos.
            Intake manifold...I don't believe there is a difference between vanos/non.
            Can be from an S50 (bigger, 3.5" I believe), but can use a vanos M50 MAF.
            Knock sensors...probably not a difference, you just need them from an M50. About $50 each.
            Honestly though, if I had known how much extra work and money would need to be done to go from M50->M52, I would have gone the whole 9 yards for an S52...same work, more power.
            • Bimmerfanatik
              • May 2004
              • 5349
              huh. well, you're doing the swap and saying it's not worth it. Guess that sort of sums it up. Now I get to read about your other suggestion. What was it again?
              PS - If anyone is interested in that M52TU, let me know.
              • permit
                • Mar 2005
                • 3363
                Oh, it'll be worth it. But an S52 wouldn't have hurt...well, maybe the wallet.
                3.2L M50 non-vanos with badass cams...duh! (This is what Bryson is planning for his M3)
                • Bimmerfanatik
                  • May 2004
                  • 5349
                  Well, if it's bad ass enough for Bryson and an M3, it's bad ass enough for me.
                  Can I PM him for more info? (aka what I'll need, etc.)
                  • Brew
                    • 3060
                    Just to clarify- All OBD1 intake manifolds are the same, as in M50, M50tu, and S50. Common upgrade for the OBD2 M52/S52 guys.
                    '91 318is
                    • Bimmerfanatik
                      • May 2004
                      • 5349
                      Nice, thanks Brew - I wasn't sure if the non-vanos intake mani was different from the rest.
                      • golde30
                        • 11464
                        thats classic r3v-tastic..r3v-erific...r3v-alicous...r3v-apalooza... :D
                        IG: @Baye30
