What are these?
  • reelizmpro
    • 9559
    why? you don't have the remote. I guess if you looked for the valet switch you could possibly activate it to see if it's working. Turn the ignition on and flip the valet switch and see if the LED comes alive. Or perhaps just take it to a shop and ask them to check it out.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • 88SuperETABD
      • Apr 2009
      • 911
      I have that same light, and clifford alarm, mine works, I might have an "idea' of what that switch does. My alarm, which has same light, No clue what model mine is or yours, but there is a possibility theyre the same. Along with the alarm system there is a "valet mode" or something. if i flip it, the alarm will be de activated. For example, if your valet driver decides to open the car with a key instead of the remote the alarm will go off, and if you flip it the alarm will shut off.
      I dunno if that helps, just kinda what I have figured mine might be used for? my switch is mounted in the kick panel tho kinda by the hood popping lever.
      And if that doesn't make sense, sorry, be 420 friendly.
      (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
      1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
      • miichaelsmith
        • Aug 2011
        • 300
        Where's the valet switch?
        • Stanley Rockafella
          • Aug 2011
          • 4062
          no such animal on an e30 my friend
          • miichaelsmith
            • Aug 2011
            • 300
            I really am just curious about this mystery switch
            • miichaelsmith
              • Aug 2011
              • 300
              I guess ill just take it to my mechanic and see what this mystery switch is
              • delatlanta1281
                Dart Master
                • Mar 2006
                • 10317
                For real? Why not just trace the wires?
                Yours truly,
                Rich
                you kids get off my lawn.....
                • reelizmpro
                  • 9559
                  The Valet switch is an alarm bypass of sorts so it should be hidden away, not out in the front panel like your switch (unless the installer was an idiot).
                  88 M3 - LACHSSILBER
                  • bmwguy325is
                    • May 2011
                    • 1263
                    Check under the seat.That switch may be for an ejection seat or an outrigger of some sort.
                    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                    • mr ilia
                      • May 2011
                      • 582
                      Originally posted by Jparkr
                      The little button in the second picture deactivates the rear window switches. if you have children in the back. (or retarded friends who like to throw shit out of your E30 and you need to cut the windows to stop them)
                      Thanks, i never knew what it was.
                      • Nick_S
                        • Apr 2011
                        • 3658
                        I just wanna know if it works or not ha
                        Lock your car and then break in. Should be obvious if it works.
                        91 318is M50 swapped
                        05 Honda Pilot
                        24V swap thread
                        • OdSkE30
                          • 375
                          This should be obvious but leave a window down when you're testing the locks. Don't need ya getting locked out. Seems stupid but I've seen people do it.
                          -Joe
