Why are these odometer gears so expensive?!
  • Nick_S
    • Apr 2011
    • 3658
    Been wanting to fix my odometer and since Bavauto sells the gears figured I'd go order them. I knew they weren't real cheap but $25 a piece? For a tiny freakin plastic gear??
    What kills me though is this gear, the E2 one is $25
    And this one, the E1 gear is $25....for this tiny little piece of plastic that is 20x smaller than the E2 that costs the same? WTF.
    Now I don't know which are stripped or broken on mine but I was blown away that if all need replaced, it appears you'll have to spend $100 for a couple ounces of cheap plastic.
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
  • slammin.e28
    שמע ישראל
    • 12054
    They are Odometergears.com gears. Good, proven stuff.
    • Nick_S
      • Apr 2011
      • 3658
      I'm not doubting that. I guess I just don't understand how they can justify the price of that tiny gear being the same as the much larger ones.
      05 Honda Pilot
      24V swap thread
      • dude8383
        • Jan 2005
        • 10387
        It's not the size that counts ;)
        • coreyw
          • Jul 2010
          • 368
          Theres a guy on here that sells a package with 3 gears I think (maybe 4, all the ones you need to replace), for $25. Let me see if I can find his username.
          Edit: Idk how I found him, but I have his email. PM me if anyone wants it.
          S52 Swap
          Shtuff For Sale
          • slammin.e28
            שמע ישראל
            • 12054
            ODOgears is the only gears, IMO.
            I am biased though.
            • E30Gus
              • Jun 2008
              • 781
              This is the reason I'm not fixing my odometer. Can't justify the cost.
              Change my oil every few months and I'm good to go.
              • noE30
                • Jun 2008
                • 2260
                I pulled my cluster apart to try fix it with a set of new gears and none of my gears were ruined... wtf? The rod that runs through the odometer has come loose and now just spins inside with out turning the gears.. I haven't found out how to fix it yet either.
                Flickr
                @michael.colby on Instagram
                "All he needed was a wheel in his hand and four on the road"
                • Nick_S
                  • Apr 2011
                  • 3658
                  Dab of epoxy I would think would fix the issue. I'll be pulling mine apart here soon to check.
                  05 Honda Pilot
                  24V swap thread
                  • dogsbark26
                    • Nov 2008
                    • 533
                    Economics theory predicts that if you are the only source for a product you are free to price your product at whatever level you desire.
                    I got my gears at Odometergears.com. I paid the price and they work correctly.
                    • LJ851
                      • 7919
                      The plastic in the gears is prob the least expensive part in the whole process of bringing those gears to the market. Both gears have to be designed, prototypes made and tested, permanent molds made, and then produced. It doesn't make much difference that one gear uses a little more plastic when you factor in all the aspects that affect the cost of these low volume pieces. If you were the OE manufacturer and BMW says they want XXX,XXX of them it would be a different story.
                      Lorin
                      The M30 is God's engine.
                      • Nick_S
                        • Apr 2011
                        • 3658
                        I understand the process behind the product...but they are basically just making copies of an existing part, a very simple part at that. There can't be that much R&D in a tiny plastic gear to warrant a $25 price tag IMO.
                        05 Honda Pilot
                        24V swap thread
                        • CHIF8008
                          • 3447
                          why not get metal gears? wouldn't wear out
                          -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                          -The Beauty in the Tragedy-
                          MECHANIC SMASH!!- (you all know you do it)
                          Got Drop?? ;-)
                          But of course
                          E30s are know to be notoriously really really really ridiculously good looking
                          • Nick_S
                            • Apr 2011
                            • 3658
                            Do they make them?
                            05 Honda Pilot
                            24V swap thread
                            • CHIF8008
                              • 3447
                              i thought someone on here had gotten some
                              Got Drop?? ;-)
                              But of course
