How to remove door sills???
  • ADCD875
    • Dec 2008
    • 115
    I have a 1991 318is that I need to remove the carpet. How can I remove the door sills? They move (slide) back and forth but won't budge upwards. Should I just pry them up? Worried that I'd break them...
    Thanks for any help..
  • kevdeno
    • Jul 2006
    • 45
    They are extremely tight. Breaking is common. Get the right tool, like a panel tool, to get under there and pry up on the white clips. If you have to break anything, break the clips. They can be replaced more easily. Though you'll probably have to order them online since the local Autozone/O'Reilly's/Advanced won't have them.
    And whatever you do, don't even try to remove them in the cold. The plastic will break it's so brittle.
    Just go slowly and don't apply too much pressure to the black plastic.
    Worst case scenario, you'll have to buy replacements on ebay or something.
    • Streichholzschächtelchen
      • Jan 2009
      • 1670
      Tear them off, go to pick n pull, tear them off more cars, accumulate clip things, replace, no headache or time wasted.
      Jah bless! :pimp:
      • freeride53
        • 11972
        Yeah I broke 2/4 of mine... it's pretty hard, even with being carefully.
        1983 Peugeot 505 STI
        1992 Volvo 240 Wagon
        • F34R
          sLaughter
          • 12376
          Two long flathead screw drivers, it is fucking easy to get them off.
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
            • Jan 2009
            • 1670
            Too much thinking involved for r3v.
            Jah bless! :pimp:
              • Jan 2009
              • 1670
              How the fuck do you expect half the members on this adhd ridden forum to track down and keep a hold of two screw drivers at once?
              Jah bless! :pimp:
              • Raxe
                • 5346
                Same way as the door moldings, just apply steady upwards pressure and it will pop off.
                • ADCD875
                  • Dec 2008
                  • 115
                  Thanks everyone.. They are $18.00 a piece at Pelican. I will try not to break them but if I do, oh well..
                  • Bey
                    • Jul 2008
                    • 479
                    They break all the time. Just go to the junkyard and get your replacement clips there for under a buck.
                    RIP
                    • Jand3rson
                      • 37587
                      Pull them straight up, don't worry about breaking them.
                      If they snap in half, now you have a legitimate excuse to get M-Technic ones. :D
                      • dogsbark26
                        • Nov 2008
                        • 533
                        I thought they were supposed to slide off!
                        I just slid toward front till back clip was free, then slid toward back till front clip was free. From there it was easy to slide out of the rest of the clips.
                        • ADCD875
                          • Dec 2008
                          • 115
                          I broke both sides!!! Oh well.. Where do I get the M-Technik ones?
                          • bernzpeed
                            • 3917
                            take the bottom rear seat out and slide it out. duuhr.
                            89 E30 S52
                            Transaction Feedback.
