well thats disappointing.
    ha soooo true
    Originally posted by Wh33lhop
    This is r3v. Check your vaginal sand at the door.
      looks like my e intake manifold
        What kind of benefits would you expect with the 885 head? Anyoneknow of someone who's done a dyno and have seen before and after results?
          No benefit dude. It already has the 885 head if its an 88 Eta. (this is fact plus the 2.5 casting verifies this)
          Difference is it only has single valve springs and does not have the "i" cam.
          So its the cam that will give you the gain.
          Don't worry about either. Just get the maintenance up to par and start modding the regular stuff like suspension and wheels.
          Then r3v it. :D
            Hotter cam, double valve springs. When you swap ECUs you will get better performance. So on and so forth. It WILL be faster than a stock 325i. Shit, my 2.7 with the flat top pistons and a cam is faster than a stock 325i and it isn't even tuned. I would expect a SETA motor to be faster than mine with the same cam.
            If I were you I would buy an 885 head, rebuild it, add a 272 cam and some tuning and call it a day. You do need to buy an 885 head from a 325i though since the Seta heads were only 4 bearing and 325i's are 7 bearing.
            Link to my dyno: http://www.r3vlimited.com/board/showthread.php?t=228618
            -Alex
              You actually are winning pretty good for $500
              I would be stoked!
                You shouldn't feel too disappointed. I was actually looking for a SETA before I bought my 325i. It could be a fun and relatively cheap project. I also wouldn't worry about the compression differences, since it doesn't really amount to much in the end. There is some good info on 327i projects around here, but I think the best place to look is here:
                  swap it
                    it still an e30 and they make the panties drop
                      E30:dropping panties in a town near you!
                        Originally posted by Teaguer View Post
                        From the lack of pics I'm guessing you also bough a digital camera only to find out later it was a stapler.
                        lulz
                        Originally Posted by ACMF74
                        i clicked on this cuz i saw p3nis
                          huge fail on my part.
                          Shit happens....make the best of it. I'm still sorry I sold my Seta, give it a chance.
                          -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
