Breaking into an e30
  • Dj Buttchug
    • Jun 2010
    • 7680
    Is there any special trick to doing this WITHOUT ruining locks/ shattering windows ect...
    I know the hood can be popped with a screwdriver. I dont have access to a wedge and pump or a slim jim so thats out.
    Just want to see if anyone here knows special tricks.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
  • DREWHALL
    • Feb 2006
    • 1207
    This isn't safe
    • 750
      • 218
      call popalock.
      http://www.mcnaughtonart.com/
      • Car Addict
        • Mar 2007
        • 1100
        The old tennis ball with a small hole against the key hole works for me
        • Blackangusinc
          • Jul 2010
          • 244
          I've broken into my wife's E30 by pulling out the rear windscreen. It's easy to get out if you have a small screw driver to pry out the lock strip. It took me two minutes to get in, and THREE HOURS to reinstall the glass.
          971-295-7077
          91' 318i
          • CabbE30
            • Aug 2009
            • 2358
            I dunno if this is a good idea.
            • ttrousdell
              • Nov 2009
              • 1770
              Originally posted by blackangusinc
              i've broken into my wife's e30 by pulling out the rear windscreen. It's easy to get out if you have a small screw driver to pry out the lock strip. It took me two minutes to get in, and three hours to reinstall the glass.
              +1
              The Build:
              • trackjunkie21
                • Jan 2010
                • 3962
                Damnit buttchugz, why you boosting cars? Because Toretto!
                Originally posted by Wh33lhop
                VANOS: sometimes you just need to go full retard.
                • RoadWarrior
                  • Jan 2011
                  • 77
                  Wedge of wood,pry back door FRAME, Insert hooked end coat hanger. POP
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Originally posted by car addict
                    the old tennis ball with a small hole against the key hole works for me
                    rofl
                    john@m20guru.com
                    Links:
                    • Holland
                      • Nov 2008
                      • 7212
                      That's actually really clever, no damage and no suspicion.
                      Originally posted by DEV0 E30
                      • redsubdivisions
                        • Feb 2011
                        • 1762
                        Call a damn locksmith. Why risk breaking something?
                        1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                        2012 Passat TDI - DD Duty
                        2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                        • BillBrasky
                          • Dec 2008
                          • 1641
                          I've done this many times. I have a slim jim that I've made out of a piece of 3/16" stainless tig welding rod. I ground the end to a sharp point and bent it around 180 degrees parallel to the rod. I slip it down past the window gasket, turn 90 degrees and the point digs into the bottom of the plastic lock button and I lift up. It usually takes me all of about 5 seconds and I'm in.
                          • FLG
                            • Sep 2011
                            • 3165
                            Is it double locked?
                            If not, this will work
                            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                            • Dj Buttchug
                              • Jun 2010
                              • 7680
                              because lock smiths cost money. why call when i can do it myself.
                              some good ideas up in here.
                              http://www.youtube.com/watch?v=5YJzpaz0tmw
                              awesome!!!
                              Ig:ryno_pzk
