how to make an e30 feel more "planted"
  • davem
    • Jun 2010
    • 705
    Is it possible to make an e30 feel more "planted"?
    that is, improve things like high speed stability and composure over shitty roads - or will the car always be limited by its engineering? I know that maintenance of suspension/steering parts/tires is key as I've driven heavier/wider cars that have felt less planted than my e30 due to being worn out.
    e.g.
    -stiffer springs
    -wider wheels/tires
    -other suspension mods etc.
  • Kershaw
    • 11822
    yep
    AWD > RWD
    • delatlanta1281
      Dart Master
      • Mar 2006
      • 10317
      It's a light car. But mods will help.
      Yours truly,
      Rich
      you kids get off my lawn.....
      • BlackbirdM3
        • 2771
        I'd say my M3 is very well planted. Infact, I can't make it unsettled. I'd say a set of H&R Race springs and a very good set of struts and shocks will make a world of difference. No, you won't have a plush ride like a typical american boat, but a firm controlled ride that sicks like crazy. Also, a good set of tires will go a long way. Heck, a good set of struts and shocks will make a big difference just with the stock springs.
        Will
        '88 BMW M3
        • camshaftgsxr
          • Aug 2011
          • 416
          buy an e36? those feel like they are planted in mud
          BroWorks.com Bro is a lifestyle
          • bowtie2bimmer
            • 830
            Originally posted by Kershaw
            yep
            Holy shit balls Batman... i want one!
            1987 BMW 325ic - Emma
            • acolella76
              • 2950
              Add a LOT of weight. maybe a proper alignment for high speed stability.
              -Alex
              • Vivek
                attention whore/retard/bitch
                • 6167
                1992 Mauritiusblau Vert
                2011 Alpinweiss 335is coupe
                2002 540i/6 Black/Black
                2003 GSX-R 750 (RIP)
                • nrubenstein
                  • 3148
                  Composure over shit roads is impacted in large part by dampers and suspension travel. IMHO, the geometry changes aren't *that* big a deal.
                  As for high speed stability, again, dampers and alignment. In particular, more rebound.
                  Except when you are cornering, wider tires will make the car LESS stable as there is more tire for road imperfections to drag around (and you are more likely to hit them). Stiffer springs help to a point, but it's easy to go too stiff and make the car just bounce over the bumps you hit in normal driving.
                  Tires are also an important factor. Reasonably low profile (45-50 series) tires will provide much better sidewall control. High quality tires will also make a big difference.
                  That said, if you want it to feel like an E90, the cheapest way to get there is to buy an E90.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • ak-
                    • 12422
                    Freshening up all the rubber in your suspension including the rear end trailing arm/subframe bushings help tons from my experience.
                    The subframe/TA bushing replacement and reinforcement was night and day and helped higher speed stability.
                    It's not always springs, shocks, and bars.
                    1991 325iS turbo
                    • F34R
                      sLaughter
                      • 12376
                      I replaced all the suspension bushings with AKG polly bushings and have coilovers with high rates(in my thread below). It is SUPER planted =) Hoping the wider BBS RS that I am building will make it even more so. But honestly new bushings and coilovers make it a new animal.
                      Instagram: @BWeissLeather
                      Current cars:
                      ~ '87 325 M30B35 swap
                      ~ '87 535
                      ~ 01 540 Msport 6spd
                      ~ '06 X5 4.8is
                      • davem
                        • Jun 2010
                        • 705
                        lol love the "buy an e36/e46/e90" comments...
                        My cars has a fresh suspension: bushings (subframe, trailing arm, control arm)/control arms/tierods/H&Rs/Bilsteins and it drives great... I was just curious as to what influences the planted feel, some good info so far.
                        • CHIF8008
                          • 3447
                          I agree with everything said.
                          -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                          -The Beauty in the Tragedy-
                          MECHANIC SMASH!!- (you all know you do it)
                          Got Drop?? ;-)
                          But of course
                          E30s are know to be notoriously really really really ridiculously good looking
                          • nrubenstein
                            • 3148
                            I operate under the assumption that if you don't know you need to replace that stuff, you're probably pretty hopeless. :p Also, the OP stated that he understands that.
                              It goes without saying that worn parts anywhere in the suspension are detrimental to good handling. With good parts there offset control arm bushings will increase caster and thus increase high speed stability. Over rough roads how well matched the shock rates are with the spring rates will determine how well the car handles. To much or too little damping for the springs used is a bad thing.
