how does water get into the toolkit?
  • bastianshaw
    • Jan 2007
    • 2210
    cant seam to find any leaks, 87 vert fwiw.
  • Vivek
    attention whore/retard/bitch
    • 6167
    From the 3rd brake light. You work at a body shop...take off that light, fill the holes, and repaint the area.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • vk88ix
      • Feb 2012
      • 59
      seal
      If i remember right there's a rubber seal the goes around the light
      1988 325ix sold
      1986 325e sold
      2003 honda civic
      1989 325is lsd
      • bastianshaw
        • Jan 2007
        • 2210
        thanbks gys that makes sense
        • agent
          Vice Grand Pubaa
          • 7960
          Or just get a deck lid off a coupe.
          Originally posted by kronus
          • long tall eta
            • Jul 2010
            • 1536
            could also need tail light gaskets. i have a coup and my tool kit was getting wet just from the moisture in the trunk condensating when the sun beat on it. the whole top of the trunk lid would be covered w/ condensation. so check the seals too.
            • ZekeTheSneak
              • 1562
              Rear spoiler. Mine leaks there
              • F34R
                sLaughter
                • 12376
                This^ done/
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • Pac1373
                  • 1746
                  Condensation.
                  Originally Posted by ACMF74
                  i clicked on this cuz i saw p3nis
                  • stamar
                    • Apr 2011
                    • 1362
                    ya you need to take off the tool kit to see how its attached. Its real dumb and you can fix it with duct tape.
                    • Roysneon
                      • 4505
                      Originally posted by pac1373
                      condensation.
                      how does it work??
                      Originally posted by mbonanni
                      I am a pursit now.
                      • Vivek
                        • 6167
                        Ummmmm....no.
                        • Robert Fisher
                          • Oct 2009
                          • 45
                          There are two screws holding the tool kit in place. It has to be removed to access the screws for the brake light. Remove the brake light screws one at a time and put sealant around the heads and re-install them. Reinstall the tool kit.
                          Also check the wells on each side behind the wheel wells. There are drains that must be open to let out any condensation. My trunk lid gasket was leaking underneath and I removed it, cleaned out the old sealant and put new sealant in there and no more water in the trunk.
                          Bob
                          Bob in Arizona
                          • iSOregon
                            • Sep 2011
                            • 248
                            95% chance the source of your leak has already been listed here, but it might be the grommet at the base of your antenna. mine decided to bite the dust over the winter, and well, it really rustled my jimmies with all that rain we have here
                            Originally posted by BewWoo
                            That's what she said.
                            • stamar
                              • Apr 2011
                              • 1362
                              yes you need to take the toolkit out to access how the 3rd light is attached.
                              Definitely.
                              you can put duct tape around the whole seal and odds are you will fix it. yes. You will see where it leaks in and you could try to silicone it.
                              People with average IQ shouldnt have a problem fixing it, and they do sell replacement seals... which as noted dont fix the problem. its a peice of plastic held in with rubber grommets
