Doesn't a turbo effectively increase the engine discplacement?
  • etxxz
    • Feb 2006
    • 2085
    #31
    Why turbos guys?!!! seriously
    here's another concept you should explore. you don't need turbos to do the turbo's job. just bypass it by putting the exhaust directly into the intake!
    Very Tall Engine Cooling, also referred to as "VTEC", also increases engine displacement by your new interpretation of displacement ie. swept volume.
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
    • Cabriolet
      • 9620
      #32
      oh oh oh hey guys ive designed on a napkin a lag free turbo. it's fast!
      Much wow
      I hate 4 doors
      • andrewm
        • 456
        #33
        The Frank 16???
        1987 Delphin 325e Sedan - Natalie
        1990 325i 24v
        1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
        • bowtie2bimmer
          • 830
          #34
          ^you so missed that thread
          1987 BMW 325ic - Emma
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            #35
            I think you guys are missing the TRUE argument here:
            • kronus
              • Apr 2008
              • 13032
              #36
              i still think it would take off if the jets were routed to little turbines that made the wheels spin
              cars beep boop
              • Massimo
                • Jan 2008
                • 3207
                #37
                displacement
                4. The volume displaced by a single stroke of a piston in an engine or pump.
                Volume
                5. the amount of space, measured in cubic units, that an object or substance occupies.
                It dose not matter if the air going in is compressed, It is still moving the same amount of volume. Forced induction only increases the mass of the air giving you the same performance of a engine with a bigger displacement.
                As mentioned before FI gives you better VE not ci.
                • mikeedler
                  • 6707
                  #38
                  op does't like the answer here, goes to e30 tech to ask and gets the answer he wants..............WTF?
                  everyday this place just gets better and better!
                  • s14pwd
                    • Apr 2012
                    • 116
                    #39
                    These are the threads that made me want to join R3V.
                    • Jables
                      • Jan 2010
                      • 83
                      #40
                      Waahh..? Your argument is that more air is going through the engine THEREFORE it's effectively increasing displacement, which is an illogical and irrelevent statement in itself which is quite impressive.
                      For example, my dad's n/a e30 M3 has a bigger throttle body/intake/exhaust, which, by your logic of "getting more air in" (which is the logic behind ANY power gains), I could say "THEREFORE it's increasing the effective boost of the effective garrett turbocharger hanging off the side".
                      It's the same thing. Same logic. And, as you can see, same level of kid-susceptible bashing.
                      You got owned by a kid, trololool
                      EDIT: for the betterment of society I should probably say why you are wrong... Basically your argument is revolving around the fact that the turbo adds power and so can be classed with another type of car, which IS true, but not in the way that you've implied, simply because its so broad. That's why my silly argument I portrayed has just as much sense as yours. All you're saying is that a turbo car might have the same amount of power as a car with more displacement. There's no such thing as "effective displacement". All the "effective displacement" is, is a measurement of power. So you would be right in saying that a turbo decreases the relative air mass difference between a lower displacement car and a higher displacement car, but the displacement in both cannot change.
                      Hope that makes some sort of sense..
                      • OniKyan
                        • Sep 2011
                        • 671
                        #41
                        Would it be fair to say; if all other factors remained constant, an engine running at 1 bar is effectively operating how the same engine would if it were double the capacity?
                        For instance; 2.5 1JZ + 1 bar = effectively operating how a 5.0 1JZ would at atmospheric pressure?
                        M20B23 Euro 323i - The Legend Of Ron Burgundrot
                        • Jables
                          • Jan 2010
                          • 83
                          #42
                          You would have to know the mass of air at atmospheric pressure in the cylinders for both and, if they are the same, then sure.
                            • 34847
                            #43
                            no.
                            for one, a turbo isn't 100% efficient so it doesn't double the efficiency/output of the engine.
                            second, a head that can flow well for a 2.5l engine would look way different than a 5l engine. apples/oranges.
                            • 5Toes
                              • 9836
                              #44
                              He is talking about the E23 745i. A car with an m30, but marketed as a 4.5 liter because it was turbocharged
                              BMW named it the 745 because they felt the power output was that of a 4.5 liter engine
                              • slaterd
                                • Jul 2011
                                • 1731
                                #45
                                In for this...conveyor belt is going "-" displacement when plain is going "+" displacement. It should equal to 0 net displacement. However, the jet engines push on air not the conveyor belt. The air still is in "0" displacement and the jet turbine is pushing air in the "-" direction causing, by laws of physics, to push in the opposite "+" direction. Think of the conveyor belt as a useless piece of information in a story problem back in school that doesn't matter in the calculation you have to do.
                                Originally posted by Wh33lhop
                                This is r3v. Check your vaginal sand at the door.
