Doesn't a turbo effectively increase the engine discplacement?
  • b*saint
    • 3794
    Some kid was arguing with me it just forces in more air. Doesn't the rule of same amount of air but smaller volume mean increase in pressure? So if you're turbo is forcing in what a v8 would naturally be sucking in, you can say your displacement is the same (in a perfect world.) I know there is heat and all that other crap but it boils down to a turbo is adding displacement.
    Yes or no.
    Ma che cazzo state dicendo? :|
  • SpecM
    • Oct 2005
    • 4531
    It just adds more air dude.
    The engine still displaces the same volume, there's just more air (by mass) in that volume
    Sent from my Vortex using Tapatalk
    1989 cirrisblau-metallic 325i
    • kronus
      • Apr 2008
      • 13032
      Displacement has a consistent definition: "Engine displacement is the volume swept by all the pistons inside the cylinders of an internal combustion engine in a single movement from top dead centre (TDC) to bottom dead centre (BDC)."
      A turbo increases the amount of air in each cylinder during combustion, but that does not speak at all to a cylinder's volume.
      cars beep boop
      • b*saint
        • 3794
        Obviously physically it doesn't add displacement.
        • b*saint
          • 3794
          Hmm. So why did BMW include the displacement of the turbo for the engine size on old turbo BMWs?
          • SpecM
            • Oct 2005
            • 4531
            ^ marketing
            Because it sounds good
              • 34844
              to distinguish them from their N/A counterparts. In otherwords, marketing.
              turbos basically increase the engine's VE by recycling waste heat from the exhaust. That's about it.
              • Click
                • 637
                Once you hit 30 pounds of boost or so, the pressure causes the walls of the cylinder to expand out, thereby increasing the displacement of the engine...
                lol
                ส็็็็็็็็็็็็็็็็็็็็็็็็็
                I need you to exfoliate my ballsack
                Build Thread?
                • tinkwithanr
                  • Jun 2010
                  • 377
                  To make them seem better, and hopefully sell more cars.
                  Displacement of an engine is a constant unless you get into cylinder deactivation or other very technical exceptions.
                  Tinker Engineering - 2014
                  Mica - 2000 BMW 323i - The one that started it all
                  Fiona - 1975 BMW 2002 - The Definition of Project Creep
                  Heidi - 1988 BMW M5 - The piece of BMW history
                  Silvia - 2013 Subaru WRX - Stock, for now
                  • b*saint
                    • 3794
                    Ok I found my answer on another forum because I was talking about EFFECTIVE displacement, not actual.
                    Thanks anyways for your input even though it wasn't helpful.
                    • e30moneypit
                      • Aug 2011
                      • 115
                      you are thinking superchargers because they are often expressed in terms of capacity in liters..... and the rest is too difficult to explain .. search!
                      • devon.818
                        • Feb 2011
                        • 2937
                        so you agree you're wrong?
                        /thread
                        • b*saint
                          • 3794
                          /thread
                          No I agree you suck at reading.
                          • Roysneon
                            • 4505
                            Does 'b*' stand for butthurt little bitch?
                            Originally posted by mbonanni
                            I am a pursit now.
                            • CrusherCurtis
                              • 2532
                              You got owned by a kid
