i'd say get your mind off the kit. a dssr is very nice (i have one), but properly fitted linkage bushings go a LONG way on their own, and will cost a fraction of an AKG kit as you'll have to replace them anyway even with a dssr. maybe spend the money saved on solid fcabs and tie rods. there's nothing like a solid front suspension.
Help me modify my car!
Definatley not good but you still have tranny mounts keeping it from turning into a true wrecking ball. Unless if all 4 mounts sheared at once somehow, then the mounts themselves won't actually shear. They'll just slowly tear and wrip up, but you'll see the symptoms a mile away.Originally posted by Wh33lhopThis is r3v. Check your vaginal sand at the door.Comment
If the engine mounts go they can cause the fan to cut the radiator hoses.Definatley not good but you still have tranny mounts keeping it from turning into a true wrecking ball. Unless if all 4 mounts sheared at once somehow, then the mounts themselves won't actually shear. They'll just slowly tear and wrip up, but you'll see the symptoms a mile away.Comment
