how are carb'd cars rev limited?
  • lolcantturn
    • 4588
    I know our cars have an electronic rev limit, but how are carb'd cars rev limited? I always pondered
    Originally posted by TSI
    OEM+
  • VinniE30
    • 2113
    They aren't.
    But I think there's some aftermarket alternatives that will do it.
    Zinno '89 <24v swap in progress>
    • slammin.e28
      שמע ישראל
      • 12054
      Then engine will let you know when you rev it to high.
      Don't they use something in the distributor?
      • randomsv650
        • Jul 2011
        • 614
        some form of wodden block under the gas pedal
        • Click
          • 637
          Assuming the timing is also mechanical...
          ส็็็็็็็็็็็็็็็็็็็็็็็็็
          I need you to exfoliate my ballsack
          Build Thread?
          • LJ851
            • 7919
            Lots of carbed vehicles are r3vlimited.
            The common German approach was an ignition rotor with a spring loaded, weighted contact on it that centrifugal force would move and eventually touch another contact and short the spark. They are available in different rpm settings.
            EDIT: As shown above.
            Lorin
            The M30 is God's engine.
            • FunfGan
              • Jan 2011
              • 4958
              Wondered this myself, scared I'm gonna break my engine ahaha.
              Go here be happy!
              Ratchet Garage e30 V8 build.
              • BlackbirdM3
                • 2771
                Most don't have a rev limiter. They let you know when they are ready to call it quits however. Some people install MSD/Crane/ you name it boxes with adjustable rev limiters in them. Its not a hard limiter like what EFI has, its a soft limiter that you can blow through if you keep your foot in it. I had an MSD on the Datsun when I still ran points, but it didn't work with the magnetic trigger distributor that I installed. The MSD then when to the Alfa GTV and lived there till it got totaled last year. I have a Crane set up that works on the Datsun, but leaves a hole open in the side of the distributor that I don't want to leave open so I have never installed it.
                Will
                '88 BMW M3
                • euro2fast4u
                  • 545
                  • euro2fast4u
                    • 545
                    • Wh33lhop
                      • 11705
                      Valve float.
                      paint sucks
                      • euro2fast4u
                        • 545
                        bahahaha
                        • Roysneon
                          • 4505
                          Originally posted by Wh33lhop
                          Valve float.
                          :giggle:
                          Originally posted by mbonanni
                          I am a pursit now.
                          • McGyver
                            • 4634
                            Valve float.
                            beat me to it
                            • future rs
                              • Aug 2012
                              • 514
                              speaking of rev limiters. who named the site and what meaning does it have?
