how are carb'd cars rev limited?
  • JasonC
    Site Manager
    • 14451
    Originally posted by BlackbirdM3
    Most don't have a rev limiter. They let you know when they are ready to call it quits however. Some people install MSD/Crane/ you name it boxes with adjustable rev limiters in them. Its not a hard limiter like what EFI has, its a soft limiter that you can blow through if you keep your foot in it. I had an MSD on the Datsun when I still ran points, but it didn't work with the magnetic trigger distributor that I installed. The MSD then when to the Alfa GTV and lived there till it got totaled last year. I have a Crane set up that works on the Datsun, but leaves a hole open in the side of the distributor that I don't want to leave open so I have never installed it.
    Will
    I had MSD Soft Touch on my 70 Dart. Nice safty device to have with a quick reving engine! But most other times one just needs to use their ears/eyes/brain to know not to over rev a car.
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • Nate325ic
      • 462
      Originally posted by future rs
      speaking of rev limiters. who named the site and what meaning does it have?
      e30sport was already taken :dot:
      • Roysneon
        • 4505
        Originally posted by mbonanni
        I am a pursit now.
        • future rs
          • Aug 2012
          • 514
          haha I am new here (obviously)
          sorry for lack of knowledge... :firehop:
          • Emre
            • Sep 2007
            • 1228
            When the engine is under load, a carb'ed engine is limited to a large degree by the size of the Venturi. Once you've hit max air flow, the engine isn't going to spin any faster.
            1987 Mercedes 190E 2.3-16: Vintage Racer
            2010 BMW (E90) 335xi sedan: Grocery Getter
            • LJ851
              • 7919
              While this is essentially true, it also applies to fuel injected engines and in practical application on a high performance machine would be well past the functional redline and in direct conflict with the desire for the primary engine components to remain in the same zip code with one another.
              Lorin
              The M30 is God's engine.
              • Emre
                • Sep 2007
                • 1228
                That's true for fuel injection, but not carbs. The size of the venturi is the primary factor that controls air/fuel flow. If you make the venturi too big, the airflow will slow and it'll stop pulling fuel in.
                It's a very different game with fuel injection.
                • Kershaw
                  • 11822
                  check urban dictionary.
                  AWD > RWD
                  • LJ851
                    • 7919
                    3/4 of the vehicles i have ever owned in my life and 2/3 of them now are carbed. Every single one was capable of going past the redline of the engine with no problem.
                    A large venturi affects low rpm running much more than high rpm/over rev.
                    In my experience it is an unusual engine design (carbed or injected) that can run out of breath before the rpm limit. Valve float is the typical reason.
                    A typical example would when my Ducati M900 was carbed with electronic ignition and no rev limiter (stock). Power falls off sharply at 7500 rpm and there is no point in revving past that number even though redline is 9000rpm. You can feel the bike slow down if you rev it that high. That engine will rev past well 10000 rpm no problem even at part throttle.
                    Lorin
                    • TobyB
                      • 5297
                      Valve float.
                      Actually, most older v8's that have hydraulic lifters do exactly this-
                      the lifters pump up over about 4500 (or something) hold the valves open, and the
                      nut behind the wheel goes, 'oh, better shift' and grabs another gear.
                      But those are non- interference engines.
                      The simple answer- carbed engines use ignition limiting. It's a bit messier than
                      cutting the fuel, but it works. MSD6AL on street and race 2002's...
                      Those rotors with springs are a hoot- but they don't work all that well.
                      The drop- off in carb flow isn't really a rev limiter. It's a shift aid, but it doesn't
                      keep you from putting it in neutral and sending the rods out the sides of the block.
                      Older things had to be taken care of better....
                      t
                      • Emre
                        • Sep 2007
                        • 1228
                        Good point.
                        I guess that's the effect I was trying to explain. You get a flat-spot at a certain point and there's no point in revving any higher. Sort of a "natural" flow-limted rev limiter.
                        Your point is well taken that you can keep pushing past that ... but there would be no reason to do so.
                        Anyway, this discussion is very interesting to me. I have limited experience with carbs (only two of my cars have had them), but I'm planning on putting twin Weber DCOE's or SK Racing carbs on the Cosworth. Been doing tons of research lately.
                        • LJ851
                          • 7919
                          ... but I'm planning on putting twin Weber DCOE's or SK Racing carbs on the Cosworth. Been doing tons of research lately.
                          I am a carb lover. There is an organic feel to a well set up carb that fuel injection does not possess.
                          ITBs will always outperform DCOEs or similar as they can be very large for max power and not suffer the ailments of a weak vacuum signal at low rpm. The carb must compromise between low rpm driveability and max power.
                          Run the smallest chokes that give you close to max power for best results.
                          And post up some pics.
                          Lorin
