Must-Do E30 Projects
  • ClayW
    • Apr 2011
    • 377
    What are the "Must-Do" projects for every E30?
    I got my first E30 about a month ago and I've been taking care of a lot of small issues (and I've found a lot of great guidance here). So, what projects should be done on all E30s, regardless of personal taste.
    So far, I've done the following:
    Red/Black Wire Fix
    Replaced Driver Door Lock Cylinder
    Odometer Gear Replacement
    I plan on doing:
    E36/Z3 Rack and Pinion Swap
    Short Shift Kit Installation
    What else should be done to every E30?
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
  • lambo
    Captain Scene Points
    • 10953
    Bushing refresh
    R-134a Conversion
    E36 Window Switches
    • tak7
      • 856
      Clutch stop
      • Roysneon
        • 4505
        Subframe bushings
        iS lip and a drop.
        Originally posted by mbonanni
        I am a pursit now.
        • Raxe
          • 5346
          Remove power steering belt.
          • mrcheezle19
            • Apr 2012
            • 1451
            maintenance. Other than that IS lip
            Dude this is r3v. 20 bucks gets you a used timing belt or a low mileage head gasket
            • dougie30
              • Apr 2012
              • 1708
              turbo
              M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
              • mrcheezle19
                • Apr 2012
                • 1451
                s54 supercharged
                • bastianshaw
                  • Jan 2007
                  • 2210
                  lukebox
                  • Wh33lhop
                    • 11705
                    Originally posted by lambo
                    Don't do an R134 conversion if you can still source R12.
                    paint sucks
                    • Vivek
                      attention whore/retard/bitch
                      • 6167
                      Short shifter, coilovers or springs+dampers, every suspension bushing, rack swap. No matter what you're going for these are good mods on every e30. The rest will depend on your goals for the car.
                      1992 Mauritiusblau Vert
                      2011 Alpinweiss 335is coupe
                      2002 540i/6 Black/Black
                      2003 GSX-R 750 (RIP)
                      • Mike30e
                        • Jan 2009
                        • 410
                        What is the purpose of removing the power steering belt?
                          Unless you have acquired a meticulously maintained very low mileage E30 my list of Must-Do tasks looks a bit different. And it would be:
                          O2 sensor
                          New distributor, ignition wires, & NGK ZGR5A plugs
                          Timing belt, tensioner, and cam seal
                          Belts
                          Air & fuel filters
                          Radiator, expansion tank, cap, waterpump, hoses, & fan clutch
                          Shocks
                          Control arms, bushings, and tie rods
                          Subframe, trailing arm, and differential bushings
                          Motor & transmission mounts
                          Guibo
                          Shifter bushings
                          Rebuild calipers, replace soft lines, and flush
                          Check the fuel tank for rust and if so replace or acid clean and seal
                          Replace all bulbs in the car
                          New half shaft boots
                          SI board batteries
                          Odometer gears
                          That only covers the things that have a finite service life and/or a scheduled replacement interval. Other things fall under the check and possibly replace, like:
                          Wheel bearings
                          Transmission seals
                          Differential seals
                          Engine seals
                          Clutch
                          Door locks
                          HVAC system
                          Wipers
                          Some things can be dropped from the list if you have proof of their recent replacement.
                          • glucklich21
                            • 1912
                            Missing the point really. 20+year old AC components are most likely shot regardless of what freon you use.
                            • CrusherCurtis
                              • 2532
                              ^My a/c still works.
                              s50 swap!
