Must-Do E30 Projects
  • bastianshaw
    • Jan 2007
    • 2210
    Originally posted by Mike30e
    What is the purpose of removing the power steering belt?
    Increase "feeback" w the stock rack, draining the fluid after removing the belt reduces steering effort.
    • bastianshaw
      • Jan 2007
      • 2210
      Originally posted by jlevie
      Unless you have acquired a meticulously maintained very low mileage E30 my list of Must-Do tasks looks a bit different. And it would be:
      O2 sensor
      New distributor, ignition wires, & NGK ZGR5A plugs
      Timing belt, tensioner, and cam seal
      Belts
      Air & fuel filters
      Radiator, expansion tank, cap, waterpump, hoses, & fan clutch
      Shocks
      Control arms, bushings, and tie rods
      Subframe, trailing arm, and differential bushings
      Motor & transmission mounts
      Guibo
      Shifter bushings
      Rebuild calipers, replace soft lines, and flush
      Check the fuel tank for rust and if so replace or acid clean and seal
      Replace all bulbs in the car
      New half shaft boots
      SI board batteries
      Odometer gears
      That only covers the things that have a finite service life and/or a scheduled replacement interval. Other things fall under the check and possibly replace, like:
      Wheel bearings
      Transmission seals
      Differential seals
      Engine seals
      Clutch
      Door locks
      HVAC system
      Wipers
      Some things can be dropped from the list if you have proof of their recent replacement.
      can get this all done in a day:-)
      • Vivek
        attention whore/retard/bitch
        • 6167
        Not sure if you're serious, but you can do a proper PS delete with two <1" rubber hoses from Kragen (got mine for free). You have to remove the whole system (lines, pump, reservoir) and drain and cap the rack.
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
        • 325ix
          • Aug 2009
          • 7783
          You aren't supposed to drain the rack, the ps fluid lubricates the inside of the rack.
          • TobyB
            • 5250
            Cage.
            t
            • Jand3rson
              • 37587
              E36 window switches. If you haven't done it yet, this is one of the single best interior mods you can do to your car, you will LOVE them.
              We just did my sunroof switch, too.
              • Vivek
                • 6167
                No it doesn't.
                Originally posted by MR 325
                On my old 325e (with i swap) I deleted the power steering. I left the rack OPEN and uncapped and had no issues in 3+ years of DD'ing.
                And read this thread.
                • superboosted
                  • May 2012
                  • 667
                  E36 window switches. If you haven't done it yet, this is one of the single best interior mods you can do to your car, you will Love it
                  Why? I don't get that one.
                  • Jand3rson
                    • 37587
                    E30 switches are just a bad/old design. E36 switches are a rocker-type switch rather than a push button, are a much better design, and look much more streamlined. They just plain work and look 10x better.qOXVZAOAA**/fyVMtP8A[/IMG]
                    • Simon S
                      • Oct 2004
                      • 3758
                      floppy vent fix:
                      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                      • e30trooper
                        • 11576
                        Originally posted by Simon S
                        floppy vent fix:
                        Nice!
                        • 325ix
                          • Aug 2009
                          • 7783
                          Originally posted by Vivek
                          No it doesn't.
                          Huh, jlevie doesn't seem to think so.
                          • glucklich21
                            • 1912
                            I think most people who "delete" their powersteering are cheap bastards to fix their leaky system and are just trying to justify being such.
                              • 34839
                              no way! it's so they can show off how fuh-raze they are at hard parking meets. :p
                              the vent thing I need to do. I think the dash starts to shrink over time which is why the vents start to get loose. also we tend to put much stiffer suspensions in than what came stock.
                              I also second the E36 switches, although I haven't done mine yet. actually, the E30 switches are fine when they are new, but they do get really hard and sticky. my son can't even push them to open the windows. the contacts inside the switch also burn up, although you can sometimes refurbish them, and some of the plastic clips that hold the contacts inside the switch break too.
                              • 325ix
                                • Aug 2009
                                • 7783
                                For me it was a little of both. I really liked it better without ps.
