School me on waterless coolant in E30
  • reelizmpro
    • 9559
    Schwarzman runs Evans in his M3 and swears by the stuff. It's lifetime fluid and since there's no water, you can run it at a lower pressure. I however, decided not to use it for a few reasons. It's expensive but it is a lifetime fluid so this is fine. You have to completely flush everything and get all of the water out. If Evans does spill or leak, it's expensive to replace and is not readily available. Also, if you do go Evans, make sure you're the only one working on your car because it's easy for someone to unknowingly top off your system with water/coolant...then you'd have to go through the entire process of flushing and filling again with Evans primer and Evans. $$$
    In the end, I just decided on strictly distilled water/BMW coolant changed every 2-3 years but I do like the concept behind Evans. I just need it to be readily available. If it finds its way into an autoparts store, I may revisit switching over.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • AndrewBird
      The Mad Scientist
      • 11898
      The fact that the stuff is flammable is a bit scary. Flash point is 225-232º.
      • TehRaydarlover
        • Mar 2013
        • 544
        I'm guessing you read that here: http://www.norosion.com/evanstest.htm
        How can the flash point be at 225-232ºF when the boiling point is 369-375ºF?
        They have flash points in the range of 225-232oF.
        The Evans products have boiling points in the range of 369-375oF at 0 psi pressure.
        Might be inaccurate seeing that it is off the No-Rosion website
        Build Thread
        Rear Diff Rebuild
        Rebuildable Viscous Coupling
        Transfer Case Rebuild
        "Life is simpler with 12 valves"
        • Northern
          I like cupcakes & sh!tboxes
          • 5288
          Flash point != autoignition temperature.
          also, when would it ever get that hot unless you pour it on your exhaust?
          Originally posted by priapism
          Originally posted by shameson
          • Cletonius
            • 2809
            Looks pretty slick. I would use something like this
            - Josh
            1990 325is
            Need a shift boot?
            Looking to buy shift boot frames, PM if you have one to sell
            Here's what happens when you let the internet pick your license plate
