Does shifting at redline..
    • 34844
    Originally posted by kronus
    An engine is wearing any time it's rotating. At redline it rotates faster, so all oiled metal contact surfaces (all bearings, cam, rockers, valve seals, rings) wear faster.
    Bearings are NOT a metal contact surface
    Most engine wear is from cold starts, not revving it once warm.
    • PeteD
      • 982
      Jesse usually shifted at redline with no problem, but he was running titanium valve springs.
      • DatUtahGuy
        • Jan 2007
        • 3146
        Look at it this way, if you fap furiously fast once a month, using the recommended weight lube, you will create x amount of friction between your palm and penoose, thus causing wear.
        If you fap every day for a month with slow even strokes, you will create the same amount of wear and tear on your dick, granted over a longer period of time.
        Conclusion, win-win.
        YOUTUBE: AR Perez
        If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
        • Onizukachan
          • Sep 2012
          • 163
          owners manual specifies that part of preventative maintenance is to run the motor to red line occasionally.
          • spike68
            • Apr 2009
            • 1185
            ^just because the manufacturer says so dosent disprove that its not bad for the engine. it could be prescribed for the sake of preventing something that is much more likely to break than the engine itself. or they could be hinting to enjoy the car every now and then ;)
            I don't even own this car anymore, but I'm too lazy to change the picture.
            • 5Toes
              • 9836
              Thanks jlevie for a great answer.
              good thread
              • Holland
                • Nov 2008
                • 7212
                Gotta float dem valves...
                Originally posted by DEV0 E30
                • 5Toes
                  • 9836
                  I know this seems like a dumb thread
                  But I was curious how long an engine can last while being maintained and driven hard
                  • Wild Ride
                    • Apr 2008
                    • 739
                    Bwap bwap bwap bwap bwap
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      Sink or swim.
                      • Exodus_2pt0
                        • 5943
                        Who are you going to believe, the engineers that designed the car or some guy on the internet?
                        No E30 Club
                        • slammin.e28
                          שמע ישראל
                          • 12054
                          What if the guy on the internet is one of the guys who designed the car?
                          • e30mpg
                            • Dec 2012
                            • 187
                            Drive it like Fast & Furious
                            • Threehz
                              • 1480
                              M42 actually wears out faster at lower RPM. In it's never-ending quest to mature into an S14 it craves the redline.
                              Different strokes for different folks.
                              • Vivek
                                attention whore/retard/bitch
                                • 6167
                                How is this so?
                                1992 Mauritiusblau Vert
                                2011 Alpinweiss 335is coupe
                                2002 540i/6 Black/Black
                                2003 GSX-R 750 (RIP)
