Does shifting at redline..
  • Wh33lhop
    • 11705
    #46
    In general, how you maintain the engine will have much more of an impact over its longevity than how you drive it. Maintaining it religiously and beating the piss out of it (after properly warming it up) will be better for it than skimping on maintenance but babying it.
    Plus, you'll have zero carbon build-up. My 250k M50's valvetrain was spotless when I peered into the head. :rofl:
    paint sucks
    • Holland
      • Nov 2008
      • 7212
      #47
      Originally posted by nando
      bearings don't touch. that's why you want good oil pressure, and why losing it is bad.
      It's not gay if the bearings don't touch.
      Originally posted by DEV0 E30
      • LJ851
        • 7919
        #48
        :rofl:
        Lorin
        The M30 is God's engine.
        • GaryE30
          • 4791
          #49
          Originally posted by atmobenzin
          How is it not?
          the others explained it well, but if you like reading more
          Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
          • Kevinl
            • Oct 2012
            • 897
            #50
            It's not something I am concerned with I have Had several motors over 200k and still take them to redline most engines it's the valve train that's the limiting factor on rpm
            I had an impreza with a sloppy ass shifter this was back when Subaru engines were non interference and I money shifted it and it revved to like 8500 and it was fine
            1989 BMW 325is Lachsilber metallic 5 speed
            2007 BMW 335i KARMESINROT 6 Speed manual
            2011 BMW X5 35I
            • Exodus_2pt0
              • 5943
              #51
              Truth.
              My sedan had 250k when the timing belt snapped. Someone swapped it to a 5 speed and installed a LSD rear who knows how long ago. My point is, that I'm sure that car was used and abused, and sadly was taken out on a technicality.
              No E30 Club
              • coldweatherblue
                • 393
                #52
                first of all, a maintained m20 loves to spend time at upper rpms.
                second, i think it's common sense that running an engine at redline will expose it to more wear than keeping it at 2k rpm. meaning.. slightly more wear...
                however i like to drive my car, and in almost 10 years of daily driving an e30 and taking it to redline probably once a day (you all know that fun 2nd gear section on your commute where you can go from 20-50 fast and its fun but not really "speeding") I've never had a problem or worried about wearing the m20 too fast. As said above, wear is mostly from cold starts and failed maintenance on the part of the owner. if you save the r3vs for 1-2x daily when you're having fun driving your car, i wouldn't worry about the wear because you're getting enjoyment about your car.
                • dnguyen1963
                  • Nov 2011
                  • 2651
                  #53
                  If you redline all the time, I would worry about changing the timing belt religiously and not about the other parts wearing out.
                  • 5Toes
                    • 9836
                    #54
                    I was aware higher rpm operation equals more wear.. I was curious how much more wear
                    • GillesBigCowboy
                      • 507
                      #55
                      Redline all the time seems extreme, and abusive, esp on the road... I always feel kind of sick when I hit the limiter..
                      In m20, doesn't seem like u lose much shifting a couple hundred below red.
                      87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
                      • TobyB
                        • 5288
                        #56
                        hee... I almost tried to respond to this thread!
                        Because... not racecar.
                        t
                        • Restoman
                          • Jun 2006
                          • 1311
                          #57
                          wear is the square of difference of speed.
                          2000 rpm last 16 years.
                          4000 rpm last 4 years.
                          i'lldoitforacaravan
                          • obes
                            • Apr 2012
                            • 1156
                            #58
                            Originally posted by lambo
                            hahahaa
                            -1986 S50Turbo Sedan (475WHP/417WTQ) Castromotorsport Built (Sold)
                            -1987 Coupe (17x10.5"/17x14")
                            Castromotorsport / Buddha_Concept_designs Built *UnderConstruction*
                            Follow me on Instagram: obes_sebo
                            For more updates:)
                            Purchase FeedBack http://www.r3vlimited.com/board/showthread.php?t=278838
