Does shifting at redline..
  • Exodus_2pt0
    • 5943
    #31
    Originally posted by Threehz
    M42 actually wears out faster at lower RPM. In it's never-ending quest to mature into an S14 it craves the redline.
    Originally posted by Vivek
    How is this so?
    See the line you cut.
    No E30 Club
    • Vivek
      attention whore/retard/bitch
      • 6167
      #32
      Oh wow oops. I just reread that. My sarcasm detector was off at 8am
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
      • willworkfore30s
        • Aug 2011
        • 1090
        #33
        Drive it like Fast & Furious
        You only YOLO once!!
        • Exodus_2pt0
          • 5943
          #34
          You only you only live once once? I'm confused.
          No E30 Club
          • 5Toes
            • 9836
            #35
            so is street racing good for your car according to the BMW manual :p ?
            • Exodus_2pt0
              • 5943
              #36
              Drive your car for a week without going past 50% throttle.
              Then put it to the floor, note the black smoke that puffs out of your exhaust. It just clears out some of the carbon build up.
              No E30 Club
              • atmobenzin
                • 151
                #37
                Originally posted by nando
                Bearings are NOT a metal contact surface
                Most engine wear is from cold starts, not revving it once warm.
                How is it not?
                • Exodus_2pt0
                  • 5943
                  #38
                  Originally posted by atmobenzin
                  How is it not?
                  Because the oil system sends oil into the area between the bearing and journal.
                  Basically, take a ball bearing and replace the balls with oil. There is no contact between your rotating assembly and the bearings around it. This is why cold start causes most wear, because until the oil gets pumped into the bearings, you will have metal/metal contact.
                  Another reason why you should NEVER rev and engine on start up. Wait until the oil light goes out at least.
                  No E30 Club
                    • 34827
                    #39
                    bearings don't touch. that's why you want good oil pressure, and why losing it is bad.
                    • Regnar75
                      • Sep 2011
                      • 483
                      #40
                      are you serious right now?
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        #41
                        Oil fills the void between the metals, creating a buffer, if you will. When you get metal on metal with bearings, you get a nasty banging noise.
                        • agent
                          Vice Grand Pubaa
                          • 7960
                          #42
                          Ever seen a soccer mom in a decade-old mini van realize too late she shouldn't have pulled out in front of you and mash it? That black smoke.
                          Originally posted by kronus
                          • Regnar75
                            • Sep 2011
                            • 483
                            #43
                            always assumed it was because it was a decade old mini van....
                            • Exodus_2pt0
                              • 5943
                              #44
                              All about how it's driven.
                              I have a 94 Trans Am with 5x,xxx miles on it that I baby. My father bought it brand new, and I have taken it over. I get on it probably once or twice a month in the summer when I have it out, and on the first hard accel it will smoke like a diesel. Just on the first pull,,for about a second, after that nothing. Granted it does run a bit rich, but just goes to show that you do get a build up under easy driving conditions, and once you get some air flowing through, it will clear it out.
                              No E30 Club
                              • Xat1cZ
                                • 2020
                                #45
                                Especially remember to always keep dem new diesels at low rpm's, gotta keep dat DPF temperature steady!
