double barrel intake
    • 34844
    the volume is way too small. also, people complain about the size of the throttle plates (too big), not the plenum size. even the standard dbilas plenum is too small.
    • Nick_S
      • Apr 2011
      • 3658
      I know nothing about actually making intakes but it seems like a cool idea. Refine the length and size then have it made from alum. That sound is fantastic though!
      91 318is M50 swapped
      05 Honda Pilot
      24V swap thread
      • NV325i
        • May 2012
        • 236
        Like your carbon fiber firewall cover. Where did you get that?
        Current: '92 325i Vert
        Past: '84 Euro 320i -Had to leave in Italy
        • AlphaE
          • Sep 2011
          • 503
          yeah.... where did you get that cover?? and i totally get the for funsies. but it looks awful:) but so does my tuneable muffler held together w sheetmetall screw. Lets here it for crappy looking projects that provide a learning experience:)
          Now with 2.7i power!!!
          • lowsodium
            • Dec 2012
            • 289
            I always thought it would be nice to have a smaller intake on top. The stock one is pretty big and covers everything underneath it.
            Haven't you ever seen Russian Nesting Dolls? They work like that.
            1987 325e / 2008 135i
            • fporro
              • 1860
              I'll copy and paste my reply from www.e30tech.com ...
              Just by coincidence our firing order is 1/5/3 and 6/4/2 which is same as how i've made them, isn't that better for velocity since there's less pause between pulses ?
              I'll make a 1/2/3 & 4/5/6 set after weekend and will thighten tension on "sock filter" to visualise resonating waves even better.
              PVC pipes are available at any home improvement shop. $25 worth at the most., don't forget the proper glue for them.
              CF heater fan cover was 79 Euros, link does not work anymore (post # 6) but better pics here ... http://www.r3vlimited.com/board/showthread.php?t=175415 ... BMP used to sell them too.
              Here's what I've seen at local yards so far, all inline 6 cylinder type:
              - This first three pics are from same manifold, I like how it splits, accumulates and then merges at center (2 mergers + 6 cylinders) to stabalize pulses ???
              - This ones are imular to log type I made, first it's the only one with tappered design...
              - Ford's dual ported ...
              - Toyota's look like a smaller version of our big six series cars ...
              I do have a dbilas/m20 compatible CSL like plenum that's requires brake booster delete, opted to chop it up and looked inside, is not very smooth and it can be repatch ($50), no big deal.
              Realistically I should have made a 1 1/2" (37mm) spacer to move brake booster foward, that would have stopped runner #6 from colliding with PVC ones, CF one has runner pointing towrads front so spacer would not help., last pic from sellers website, notice lack of brake booster., it also required throttle cable bracket to point up instead of to the left side, did that already.
              while in the subject of electrically activated split plenum's, bought this M70 fly by wire throttle kits, sent one to Keith whodwho, maybe he'll get into it ;)
              thanks for pleasent conversation.
              • TobyB
                • 5287
                ...i think it should be clear plastic...
                hee hee, for fun, it's fun! For serious, it's ghetto!
                t
                • LJ851
                  • 7919
                  t
                  Ooooohh, Fish Tank Plenum !!
                  I can see it now.
                  Lorin
                  The M30 is God's engine.
