missing wheel!
  • Digitalwave
    is a poseur
    • 6299
    Matt, put some locktite on those beasts.
    RISING EDGE
    • tonytony
      Knee deep in poopie
      • Jan 2004
      • 3498
      it was the bolts the tire store gave me with my wheels, blah. today I just noticed I cracked the paint a bit too!!! :evil:
        • 34844
        what are you guys torquing your wheels to? I do mine at 80 ft-lbs.
        • Digitalwave
          is a poseur
          • 6299
          On second thought, are you that dumb that you couldn't tell the wheel fell off the hub and was just resting in your fender well? You needed Jordan to tell you?
          RISING EDGE
          • SlammedE30
            • 741
            I torque my wheels to 85 ft-lbs, but for track use I up it to 90 ft-lbs.
            -Ted
            • MattM20
              • 641
              i looked into getting some locktite 262, but i'm not sure how bad the lugs are, theyre probably all due for a replacement. i think i should just buy 16 new bolts plus locktite
              • tonytony
                Knee deep in poopie
                • Jan 2004
                • 3498
                it was dark and I had no flashlight!!!
                • Numbersix
                  • 74
                  'Almost rolled my ankle'...You stopped at the Peacock for a beer, didn't you...
                  • m42technic
                    • 1056
                    The factory spec is 120Nm, or about 90ft/lbs. :!:
                    James Peacock
                    WWFSMD?
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      I had a simular experiance with my MG. There are 8 bolts per wheel that hold the wheel to gether with nuts on the outside. I came back from driving and ALL 8 NUTS WERE MISSING. The bolts did not have anyroom to fall out so they stayed in, but the threads are stripped. The only thing that kept the wheel from just turning freely was that one of the bolts that cam loose locked up against one of the bolts that hold the rear drum on. I still haven't found the right bolts to fix it.
                      Andrew
                      • Ryan Stewart
                        I Love Miatas
                        • 8978
                        74.5 foot-lbs or like 100NM. Whatever the Bentley says, hasnt steered me wrong yet.
                        Im now E30less.
                        • UNHCLL
                          • 8790
                          Andrew
                          I am so confused.
                          after seeing this pic:
                          I could swear you were like 10.
                          You have an MG? :oops: So foookin confused
                          My appologies if I'm way off here.
                          Below the radar...
                          • tonytony
                            Knee deep in poopie
                            • Jan 2004
                            • 3498
                            ok so maybe I finished off a half gallon while I was walking home, I had to have something to keep me company on the long trip on foot.
                            • 325 eta
                              • 472
                              look around see if anyone hates you, then loosen up the lugs on their wheels.
                              eye for an eye
                              • tonytony
                                Knee deep in poopie
                                • Jan 2004
                                • 3498
                                haha I dont think anyone hates me, not around here at least. Well lug bolts I say good bye to, I'm going with studs. Hopefully these will do me good.
