Dynotuning tomorrow. Poll.
  • matt325is
    • 409
    Alright guys, the time has come to dynotune my car again. I have been waiting a while, and now the time is right. What are your guys' guess for my hp numbers? I'm dyno-ing at Carb Connection on a Dynojet dyno, at 10:30am.
    Here is a reminder of what I got last time.
    later,
    matt
    0
    200hp
    0%
    0
    250hp
    0%
    0
    300hp
    0%
    0
    325hp
    0%
    0
    350hp
    0%
    0
    BOOM!
    0%
    0
  • Digitalwave
    is a poseur
    • 6299
    I would put money down for inbetween 250 and 300 rear wheel horsepower.
    RISING EDGE
    • e9nine
      • 1890
      :stupid:
      • Brian 89 325i
        • 1450
        Whats been done since last time?
        Brian
        • Charlie
          kid tested, administrator approved
          • 6686
          What have you done to the motor since the last pull? If it's just messing with the megasquirt stuff, then I'd say 200-215 hp.
          Frankly, from what I've seen, I'm less than impressed with the results of MS.
          -Charlie
          Swing wild, brake later, don't apologize.
          '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
          FYYFF
          • matt325is
            • 409
            Centerforce dual friciton clutch, 12lb flywheel, Walbro high flow fuel pump, new fuel filter, wastegate goes into exhaust now. Fixed oil leak. (now i have one VERY SMALL leak from somewhere). You do know that the blue turbo graph on the sheet ends at 3700rpm correct? If you remember, I had to quit because my stock clutch failed after 3700rpm.
            matt
            • Digitalwave
              is a poseur
              • 6299
              3,700 RPM; I rest my case.
              RISING EDGE
              • SlammedE30
                • 741
                I'm guessing 275 to 300. Hopefuly I'll be a witness :D
                -Ted
                • randomtask37
                  • 3154
                  i wana c u hit 300!
                  make that sohc work its ass off!
                  98 M3/4/5
                  • reelizmpro
                    • 9553
                    A turbo is a big variable! I think if you stay below 10PSI, I'd guess around 250-260rwhp give or take. Your graph looks pretty damn promising...I can't wait to see what it does. If you raise the boost and things stay together, you'll definately see 300+rwhp. Goodluck.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                    • Red325es
                      • 140
                      I hope to see you put down between 250 and 300 to the wheels as well :!: Good luck :!:
                      • E30godz
                        • 1524
                        God i love your car....one question though...one graph is for the 2.8 without the turbo, and the 2.8 with the turbo correct? Looks as though your seeing boost coming in after 3 k....what about the numbers before then? since both cars would be "off boost" up to that point, why does the turbo car make 25 more HP off boost? Maybe i missed something
                        • jbob
                          • 74
                          the turbo's turbine is still spinning (therefore blowing/compressing some air) below 3k rpms at WOT, but the turbo isn't quite 'spooled' to give full-boost just then. that relatively low power before 3.5k rpms or so is just turbo lag from the nice t4
                          based on that first dyno chart & no tunning/fuel problems in the upper rpms, i think matt's car is going to hit more than 300rwhp, i think closer to 325rwhp (altho hoping for more 8) )
                          m10 engine build photogallery
                          • Super Eta
                            • 1884
                            that thing will have more horse under the hood then an S14
                            Correct me if im wrong
                            How much is this dyno tuning gonna cost?
                            I want to get my car redynoed after i tune it up and if possible get a comparison for both of the chips i have adn see if i got a real copie of a dinan chip. :P
                            • OreoGaborio
                              • 1285
                              um.... it already does, ryan ;)
                              -Pete
                              LRRS/CCS#187 ECK-Racing, Ironstone Ventures, Tony's Track Days
                              Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsport | Motorcycles of Manchester
                              The Garage: '03 Tuono (Hooligan bike :naughty) | '06 SV650 (race)
