Alignment Shop Damaged Catalytic Converter, Advice?
  • RCM3
    • Aug 2011
    • 1304
    Probably not the most ideal location for this thread, but I was really hoping for some solid advice.
    Quick background: I took my 1988 325iS to Wheel Woks in San Jose, CA (the one on Winfield and Blossom Hill). The balanced my wheels and aligned the car. When I got the car back I noticed something hanging underneath, and heard it when they drove the car up. The scraped the lower cover off the catalytic converter, completely mangled it. I tell the tech driving the car out to me, and he grabs a manager and we stick it on the lift. In the air, one guy rips the thing off, sending all the insulating material flying, and leaving the top cover just to float around and rattle on top of the cat. They offered to pay the shop next door to re-weld the salvageable top cover, but they quickly removed the other pieces and never mentioned them. I had the manager document the issue, and I left with the car (hopefully that doesn't come back to haunt me, as in Im on the hook now since I took the car home but they were closing).
    My question is, how crucial are those covers on the cat? Does it help the cat get to proper operating temp? Or is it just a safety heat shield? Im sure it was already skinned up a bit from speed bumps over the years, but now its completely missing and I want the car taken care of properly. Again, the top one is still present and can be re-welded by the exhaust shop next door.
    Any input would be greatly appreciated.
    -Ryan
    05/87 Henna M3
    04/71 Baikal 2002tii
  • kronus
    • Apr 2008
    • 13032
    the cat heatshield should be between the cat and the body. if yours was below the cat, it was installed wrong in the first place.
    cars beep boop
    • Cletonius
      • 2809
      Post a pic. My cat is only shielded by the bolt in covers that hide the driveshaft. Nothing between it and the road.
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • SedanSandwich
        • Feb 2011
        • 314
        The heat shield helps protect the cat from minor impacts with rocks/other debris and they also protect equipment close to the cats from being damaged by the heat of the catalytic converter. If I were in your situation I would want the shop to get it back into the condition it was in before the damage. Make sure the ceramic/other interior components of the cat are not broken. They are very fragile.
        • RCM3
          • Aug 2011
          • 1304
          I know the shielding youre referring to, the shielding I mean is part of the actual catalytic converter. How I understood it after the damage was that the cat itself has two layers of steel, with insulation in between. They ripped off the outer, surrounding material from the cat. Causing the cats insulation to be lost also.
          This shielding on my oem cat is like crimped, or welded on. This outer cover is what was lost. Ill try and get some pics now.
          Makes sense to me, heat is for sure a concern. But also like you said the cat must have taken quite the shot to peel this portion back.
          -Ryan
          05/87 Henna M3
          • Dj Buttchug
            • Jun 2010
            • 7688
            fwiw ive been running my daily with this material removed for 2 years. no problems to report
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • jrobie79
              • Mar 2006
              • 2526
              same^
              1991 318i ---- 308K - retired
              • RCM3
                • Aug 2011
                • 1304
                Cool, makes me feel better. I just didnt want this to pop up around smog time and be a reason why I fail. Ill have the exhaust shop thats to do the repairs run a smog check to make sure as it just passed in October, some good advice from a forum member via text. Thanks again guys.
                -Ryan
                05/87 Henna M3
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5284
                  +1 to what buttchug said. What was left of mine was hanging by some oversized hose clamps when I got the car, but it's long gone now.
                  Originally posted by priapism
                  Originally posted by shameson
                  • Exodus_2pt0
                    • 5943
                    Not going to hurt anything without it.
                    Honestly if it came off while pulling the car onto the rack, it was about time anyway.
                    No E30 Club
                    • Todd Black 88
                      • Oct 2007
                      • 3449
                      Fwiw, it's apparently there to protect grass from igniting when parked on.
                      I just removed mine because it was rattling like hell at high revs.
                      Originally posted by codyep3
                      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                      2001 silver/Blk 325 cabby. SOLD
                      2002 325xit Sil/blk. SOLD
                      2010 F650gs twin
                      • RCM3
                        • Aug 2011
                        • 1304
                        Oh really? So no more off-roading in the e30?! Good to know though thanks. So it sounds like it's not the end of the world about losing this part of the cat, but I'll still have it checked out fully tomorrow while its on tire racks dime to ensure I'm in the clear.
                        -Ryan
                        05/87 Henna M3
