Shit, my locks are frozen.
  • yozsi
    • Feb 2006
    • 337
    Well i go out to mess around with the 325 and i find out that my drivers side door wont turn. well its 0 degrees out so yea. the passengers door only locks so im screwed. the trunk lock works but thats useless. i run into the house and grab wd40 and spray the lock down, i was able to get it to lock but not turn the other way. what can i do???
    Unlimited Slip Diff's FTW!
    1972 240z Drift,Scca BSP, Scca ITS Car.
  • DEV0 E30
    • Oct 2004
    • 8893
    What's your high for tommorrow? Worse case wait.. or break a window?
    • yozsi
      • Feb 2006
      • 337
      the high for tommorow is 8-10 degrees. can i get in through the trunk?
      • yozsi
        • Feb 2006
        • 337
        oh, how about sending voltage into the lock actuator for the trunk? will that operate the other acuators also?
        • browntown
          • Jun 2004
          • 3524
          hair dryer on LOW, lock deicer, or the tried and true favorite, take a bic and heat up your key (wear gloves).
          Bad things: Hot Water, wd-40 is bad for paint be careful, forcing it.
          • yozsi
            • Feb 2006
            • 337
            well it actually seems that the cylinder turns its that something else is frozen.
            • Hatchman
              • Mar 2005
              • 1425
              dozen beat the flat I got a month ago when it was like -10 and my lugnuts were frozen solid, took 5 mins awitha blowtourch per nut to get them off
              • Jand3rson
                • 37587
                Are you drunk?
                • optimusp517
                  • Oct 2005
                  • 797
                  Are you drunk?
                  :giggle::giggle:
                  • Schneider325
                    • May 2004
                    • 3818
                    heat up the key?
                    • King Luis
                      • Sep 2004
                      • 737
                      a zip lock bag with hot water.....hold it around the whole lock area...everything inside will head and melt within a minute or so. worked for me in -15c weather (not including windchill).
                      then go get some white lithium grease and spray it on all the hinges and inside the door locks.
                      • 88325isboy
                        • Mar 2004
                        • 1058
                        Heat the car up and let the inside of the car warm up and that should get it done.
                        '87 325 (Track Rat)
                        '04 C5500 Wrecker (Work)
                        '94 525i (Daily)
                        '90 325i (R.I.P)
                        H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
                        • Jon325i
                          • 6934
                          Originally posted by Schneider325
                          heat up the key?
                          This actually works but sometimes more than one 'heating' is required. Be careful of how long you hold a flame to it....especially its an all metal key which is contacting your fingers!!! I ran into a similar issue with frozen locks a few winters back when skiing up at Lake Tahoe and a snow storm caught me be surprise. Two or three heatings of the key with a borrowed lighter got me into the car.
                          Jon
                          Rides...
                          1991 325i - sold :(
                          2004 2WD Frontier King Cab
                          RIP #17 Jules Bianchi
                          • Ryan Stewart
                            I Love Miatas
                            • 8978
                            Ive done the heating up the key thing. It has even helped when its not ice on the outside, like when the keyless wont open it. Then once I get the car thawed its fine.
                            Im now E30less.
                            • yozsi
                              • Feb 2006
                              • 337
                              well, nothing worked and its 3:15am and the wind chill is down to -30 its def not opening. oh well, anyway into the car via trunk?
