Headbolts torqued to EXTREME amount (video)
  • graveshaker
    • Sep 2009
    • 828
    #31
    I cringed reading every post and reply. Take your time op and good luck to you.
    • noid
      • 1535
      #32
      I try to spend 5-6 hours every Saturday tackling various projects on the car. Luckily the car is in storage for the winter so I am in no particular rush. Patience is a virtue though, sometimes I go for 4-5 hours during the week after work.
      I'm used to getting into involved projects with this car .
      Lets just add everything I did this winter to the list:
      Working on the car is a form of mediation for me... sometimes it turns into a nightmare, but then goes back to mediation when everything becomes clear again. Its a love/hate relationship, mostly love.
      Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
      Your resource to tools and tips: www.rtstools.com
      • AndrewBird
        The Mad Scientist
        • 11898
        #33
        FYI - A simple countersink tool would have enabled you to use the timeserts.
        • noid
          • 1535
          #34
          You want to achieve a 6mm countersink without an angle, that tool wouldn't be my tool of choice; another stepped drill of different length/stage lengths would have been better.
          I was however past the point of retooling the kit when I realized it wasnt going to work as I intended. Hindsight is 20/20, I should have just brought my block to the machinist to get drilled and serted before messing with it myself.
          • noid
            • 1535
            #35
            4 months later and the car is back on the ground and running.
            During the same time I also had the driveshaft rebuilt as both U-joints were binding.
            • R3Z3N
              • Jan 2011
              • 3056
              #36
              There are guys, not many, with tools that can electrically burn the bolts out. One of the mechanics I used out here would get calls to zap out bolts on rockets out at Vandenberg AFB, pretty cool OMO.
              Like this: http://www.bolttechmannings.com/serv...ion-machining/
              • noid
                • 1535
                #37
                Definitely a cool process, I have actually seen videos from that place before. Its crazy what machinists can do with the right tools.
                I would imagine broken bolts are a staple for most machinists and I would trust that most can atleast drill them out on center with a jig and sert the hole.
